It is currently Sun Jul 13, 2025 4:12 am
Reply to topic  [ 30 posts ]
 Got a roaring sound in a GTR
Post Got a roaring sound in a GTR
I was out and about last night and started hearing somthing in the lower unit that sounds like it's about to really come togther......
Is there a bearing thats in the front of the shaft? I know there is one on the prop end of the motor but what about the pully side? I got something that sounds like its about to go out in there.
Everything on the prop end looks good.
Sat Apr 05, 2014 9:00 am
Post Re: Got a roaring sound in a GTR
I just called them about seals and bearings the other day and from what I understand there is bearings on each end but I may be wrong
Sent from my SAMSUNG-SM-N900A using Tapatalk
Sat Apr 05, 2014 10:14 am
Yes that's true
Sent from my iPhone using
Sat Apr 05, 2014 10:25 am
Definitely sounds like a bearing, I just sent them a LU to get rebuilt, Great customer service and a quick turn around.
Sat Apr 05, 2014 11:01 am
are the bearings pressed on or held in place with snap rings?
how often are you greasing the lower unit Pearl R. O. ?
Sat Apr 05, 2014 12:46 pm
Snap rings
Sat Apr 05, 2014 4:39 pm
Kool deal to know bout the snap rings im bout to change mine and my podnahs glad u post this.
Sat Apr 05, 2014 8:45 pm
Sun Apr 06, 2014 2:08 pm
Yea may just buy the new lu and be done
Sun Apr 06, 2014 6:17 pm
Mon Apr 07, 2014 7:01 am
Mon Apr 07, 2014 7:05 am
Mon Apr 07, 2014 7:21 am
Mon Apr 07, 2014 10:22 am
Mon Apr 07, 2014 11:01 am
Mon Apr 07, 2014 1:02 pm
I purge a little grease out of mine every time i use it. Cheap insurance. I've noticed that the GTRs lose grease from the design of the LU seals facing the same direction. I like the fact that it's always losing a little at the back seal. It keeps the seal clean of debris and lubed.
17x54 Extreme W/ GTR-35L Stage 1
Mon Apr 07, 2014 4:20 pm
Mon Apr 07, 2014 4:46 pm
Well I took it apart last night and got new seals bearing race and wear sleave...... There wasn't any grease coming out the back of the shaft at all and the bearing didn't have any play or nothing in it but when I spin you can hear it roaring....Sounds like it dam dry but hell I know better!
What yall think?
Tue Apr 08, 2014 7:56 am
can you see any wear/discoloration on the rollers or races? any "metal" in the housing?
when I was working in transmission shops we seen this a lot - bearing "looks" fine but would be very noisey under load from minute wear on rolllers/balls/races
Tue Apr 08, 2014 8:04 am
Tue Apr 08, 2014 8:21 am
Grease it every time you use it? F' that.
Tue Apr 08, 2014 8:54 am
do you have a mechanics stethoscope? Very useful to pinpoint location of noises and which bearings are noisy, they are pretty cheap and kind of cool to use - you get to hear stuff like bad bearings, noisy lifters/rockers and the sweet sound of everything running in harmony.
The one thing I learned about bearings is they don't harden the the whole roller, only the surface and once that wears out they go bad pretty darn fast.
do the bearings have to be installed on the shaft in any particular way so they are lubed as you pump grease in?
Tue Apr 08, 2014 8:58 am
Tue Apr 08, 2014 9:00 am
Tue Apr 08, 2014 9:26 am
I do mine once a year with the oil change.....whether it needs it or not, lol.
Tue Apr 08, 2014 3:55 pm
Tue Apr 08, 2014 3:59 pm
Grease it before you leave then when you get back.The only real way to make sure the grease doesn't breakdown between trips. That's what I do.
Tue Apr 08, 2014 4:14 pm
Tue Apr 08, 2014 5:00 pm
Tue Apr 08, 2014 5:13 pm
Well if I can ever get this dam pully off I get to the dam bearing as of right now Im about to go ninja on this bitch......
Tue Apr 08, 2014 5:33 pm
Users browsing this forum: No registered users and 28 guests
