Goldfish23
Joined: Mon Apr 25, 2011 11:06 am Posts: 76 Location: Minnesooota
 What motor would you go with? (13/16hp)
First off, this will be going on a 14ft semi-v fishing boat, not a Jon boat so I know I won't get the optimum performance for mud motoring, but in MN I have vegetation to deal with, not mud flats.
I was looking at getting one of the mud skipper long tail kits. This Sunday, harbor freight has an extra 25% off so I could go with their predator 13hp for $260ish, or would you go with the maxtool 16hp for $300? Is the extra couple horses going to matter? Is one motor more reliable than the other?
These are the two motors I'm thinking of:
_________________ If you pick up a starving dog and make him prosperous, he will not bite you; that is the principal difference between a dog and a man.
-Mark Twain
Thu Apr 17, 2014 9:25 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
 Re: What motor would you go with? (13/16hp)
As big as you can go , you'll want every bit of power and speed you can get .
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
Thu Apr 17, 2014 9:27 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
16hp all day... Id be more worried about you choosing one of those thai kits...
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
Thu Apr 17, 2014 11:57 pm |
Goldfish23
-Mark Twain
Fri Apr 18, 2014 1:26 am |
mud slinger 69
Joined: Sun Aug 28, 2011 4:27 pm Posts: 1194 Location: Utah
Those thai kits are fine when you 1st run em then they fall apart. Alum props I've seen a few around here they just don't seem to last long. Look for a used long tail or a better frame.
_________________ We ant just mormons and polyganists we got rednecks too
Fri Apr 18, 2014 5:44 am |
SwampDonkey1
Fri Apr 18, 2014 8:04 am |
shooter1
Joined: Tue Feb 25, 2014 1:42 pm Posts: 38 Location: SETX
Check out the 18hp from vegas carts ($300). Great customer service that you will not get from HF plus they have reasonably price performance mods. I got one and will never buy another HF engine.
Fri Apr 18, 2014 9:03 am |
Goldfish23
Unfortunately, cost is an issue right now. The waters I'll be using it for during hunting season are not so much rock and stump filled, more muck and weed filled so I shouldn't be banging it around too much, and I have an outboard for fishing in the summer so this setup won't be ran a whole lot. I used the outboard last couple years, just sick of having to flush all the crap out of the cooling system.
That being said, I could buy one of those kits cheaper than I could make my own and I work at a welding shop that I can get scrap from. The shaft, prop, bearings and couplers costs are ridiculous for what I've seen. I know that these kits use aluminum props, but at 10 or 20 bucks per prop, that isn't that bad.
So, unless you are going to post a picture of a dude that looks like me bring impaled by the shaft after it grenaded, I doubt I'll be convinced, lol.
Sent from a phancy fone
-Mark Twain
Fri Apr 18, 2014 9:17 am |
SwampDonkey1
10-4 If you want to look into building one a completed frame ready for motor mount can be done for about $500 if you already have a welder, torch, ect
Fri Apr 18, 2014 9:53 am |
AJCsurf
Make sure you look at the differences between mud skipper and swamp runner. They are not the same company and are not the same product.... the extra cost for the swamp runner is worth it. The mud skipper uses a lawmower engine static throttle and has a stamped steel transom clamp that isn't beefy and will pop off your transom / bend when you torque down your transom bolts. Swamp runner has a much better transom clamp and it also has zerk fittings for all the pivot points vs the mud skipper's lack of any grease fittings on pivot points and old school grease cups only on the coupler.
I've ran into a few people that thought they were getting swamp runner kits but instead got mud skipper kits because the guy set up IDENTICAL ebay auctions, wording, pictures, and all. I would order directly from swamp runner's website and/or poke around on there to research the differences a little more.
good luck!
Fri Apr 18, 2014 10:04 am |
Goldfish23
I'll look into the swamp runner thing. Thanks
-Mark Twain
Fri Apr 18, 2014 12:49 pm |
DeltaRunner
Joined: Fri Oct 25, 2013 5:50 am Posts: 482 Location: South Alabama
Man I would take swampD's advice. You are just throwing away money with the thai kits.
_________________ 1648 GDSD 27 GDSD
Fri Apr 18, 2014 12:54 pm |
Goldfish23
Do you guys have links for a kit I could weld myself that isn't going to have me eating ramen for the next two months?
-Mark Twain
Fri Apr 18, 2014 12:59 pm |
DeltaRunner
Fri Apr 18, 2014 1:06 pm |
Goldfish23
Realistically, how much would I be looking at for prop, shaft, bearings, etc.?
What kind of tubing do they suggest/use? The metal at work I literally pay scrap prices for, or cost if I put an order in with their order if I need something so that I'm not worried about.
I guess, what exactly is the shaft anyways? If it just rolled stock that gets machined?
-Mark Twain
Fri Apr 18, 2014 1:19 pm |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
Dont do a Thai kit. I did and they blow. You will be busting props on the weeds.
_________________ 23 swomp/ 1542 tracker
Fri Apr 18, 2014 6:17 pm |
SwampDonkey1
Yes shafts are 3/4" cold rolled round stock cut to length then machined with a key on one end and 3/4" x 10 threads on the other... maybe $10 in material and we used to pay a local guy $20 a shaft to do em before we got the mill and lathe... other than that... Prop $150, Bearing $35, Bushing $10, U-joints and yoke $35, seals $15, kill switch $20, I'd say $75 in misc (nuts, bolts, ect), throttle assembly $20.... so as of now $400.... this is all I can think of off the top of my head (and prices are somewhat inflated if the part had to be shipped), if you can get materials for cheap you'd be far ahead in both cost and quality.
Fri Apr 18, 2014 8:09 pm |
Goldfish23
Shoot, I can get cold rolled stock at cost as well, and we have lathes and such back in the machine shop to put threads in and the key way.
Dammit guys, I thought I had this planned out.
-Mark Twain
Sat Apr 19, 2014 12:48 am |
mud slinger 69
Just bliuild it then you'll be alot happyer with it.
Sat Apr 19, 2014 4:51 am |
SwampDonkey1
Sat Apr 19, 2014 11:22 pm |
