It is currently Wed Jul 16, 2025 4:44 pm
Reply to topic  [ 11 posts ]
 Mud Buddy 35HD prop removal help please
Post Mud Buddy 35HD prop removal help please
So after a while of messing with it, I finally got the prop nut off. Boat and motor are new to me so haven't done this before. How do I get the prop off? I'm hesitant to hold the threads tight as I don't want to strip them. Any suggestions appreciated.
Thanks guys.
Sat Apr 19, 2014 9:28 pm
Post Re: Mud Buddy 35HD prop removal help please
Also, anyone know if the nut is supposed to be torqued when put back on? And if so, what size is it? I got it off with a crescent wrench.
Sat Apr 19, 2014 9:29 pm
If it's a hex shaft....it should just pull straight off....it may take some persuasion. If it's threaded, gotta unscrew it.
Sat Apr 19, 2014 9:54 pm
Should be a hex just hit it she'll come off. When ya put the new one on just tighen it up good prop shouldn't move back and forth.
Sun Apr 20, 2014 5:47 am
It's threaded. Turns entire shaft when trying to unscrew.
Sun Apr 20, 2014 8:08 am
did you try tapping it with a hammer straight off should be a hex shaft not a threaded
07 16x50 w/ 07 35 gtr
Sun Apr 20, 2014 8:23 am
1 1/16 wrench
Sun Apr 20, 2014 8:53 am
This what I did last time. Go buy u a second nut 7/8 course thread. Put the first nut on followed by the second. You ate using the second nut as a jam nut. Then heat the prop hub up with a tourch. If you are not planning to use that prop again beat it off with a hammer while you hold the first nut only with a 33mm socket.
While u have the prop off make sure u grease the drive. Do so by taking the bearing cap off (reverse thread).
Place a 1/4 #10 zert in the hole on the belt housing side of shaft. Fill till you see new grease come out of the bearings on prop end.
Sun Apr 20, 2014 10:39 am
B. MacDonald
Mon Apr 21, 2014 6:13 am
Thanks for help guys. Rookie mistake. It's a hex. It came off, hopefully prop but won't give me problems next time.
Mon Apr 21, 2014 10:29 am
Lol
Awesome
B. MacDonald
Mon Apr 21, 2014 4:22 pm
Users browsing this forum: No registered users and 59 guests
