It is currently Tue Jul 15, 2025 7:48 am
Reply to topic  [ 9 posts ]
 GT lower unit rebuild.
Post GT lower unit rebuild.
Anybody got any pics of the guts before I crack it open? I got the rebuild kit in and will take a stab at it this weekend. There are a shitload of o rings.... Thread research didn't prove extremely fruitful.
Thu May 01, 2014 7:45 pm
Pulley and taper lock are rusted bad. I out the Allen head screw in the extra hole and it won't back the taper off the pulley. I soaked it in WD40 to no avail. I beat the piss out of it with a plastic hammer away from the prop. Does it do any good to beat the pulley towards the prop or should I be hitting the taper lock only?
Also do you leave the Allen screw in while you attempt to get the pulley off?
Fri May 02, 2014 6:06 pm
Post Re: GT lower unit rebuild.
Fri May 02, 2014 6:22 pm
No u only hit the pulley toward the lower unit mounting flange and keep tightening the Allen in taper lock
Sent from my iPhone using
Fri May 02, 2014 6:34 pm
The bitch is stuck and rusted bad. She's not cooperating.
Fri May 02, 2014 8:20 pm
Heat it up
Fri May 02, 2014 8:26 pm
Fri May 02, 2014 8:41 pm
Fri May 02, 2014 10:33 pm
After a lengthy soaking in penetrating oil and a beat down by a new $6.00 rubber mallet. Thanks for the help guys.
Sat May 03, 2014 6:31 pm
Users browsing this forum: No registered users and 21 guests
