It is currently Tue Jul 15, 2025 12:27 pm
[ 9 posts ] |
ctrexler1
 35 GDSD speeds
I'm looking into buying a new MM, I do not really feel like spending 7500$ on a new GTR, or Mud Buddy, and I do not really want a PD because of gears (not knocking PD just don't want gears). That's why I'm looking at the 35 GDSD. If I go this route what speeds should I expect with and without a load. I will be putting this on the back of a 1650 Xpress.
Sat May 03, 2014 8:31 pm |
kirk
Joined: Thu Apr 18, 2013 5:52 pm Posts: 870 Location: SW LA
 Re: 35 GDSD speeds
I'm about to get one also, used but with under 15 hours so fairly new.. Ill be interested in the results
Sat May 03, 2014 9:05 pm |
DeltaRunner
Joined: Fri Oct 25, 2013 5:50 am Posts: 482 Location: South Alabama
 Re: 35 GDSD speeds
On the right boat you could see 30+. But thats on a true mud hull. Doubt you will see that on the express. But I could be wrong.
_________________ 1648 GDSD 27 GDSD
Sat May 03, 2014 9:14 pm |
ctrexler1
 Re: 35 GDSD speeds
Yea I know.. Wish I would've bought one in the first place! Any guess on what speeds I should somewhere expect?
Sat May 03, 2014 9:28 pm |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
 Re: 35 GDSD speeds
I run one on an 1848 go devil surface drive boat. I bump 30 at times but mostly sit around 29.2 with 1 person, ice chest, couple batteries, tools, trolling motor etc. It will push that 1650 express 30 for sure.
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
Sat May 03, 2014 9:30 pm |
WhoDat88
 Re: 35 GDSD speeds
Call CoCo and tell him exactly what you run in and what boat you have. He will put the correct trim tabs on that motor for your boat. Some boats need bigger trim tabs installed on the motor. I gave another member that same advice and he is loving life now. Coco set him up with bigger tabs and had the motor to him quickly. He was able to install the motor and go.
Sat May 03, 2014 9:35 pm |
DeltaRunner
 Re: 35 GDSD speeds
I think he will have a problem with the bow bouncing.
Sat May 03, 2014 9:37 pm |
WhoDat88
 Re: 35 GDSD speeds
Sat May 03, 2014 9:43 pm |
Assault
 Re: 35 GDSD speeds
_________________ Using Tapatalk
Sun May 04, 2014 6:49 am |
[ 9 posts ] |
Users browsing this forum: No registered users and 108 guests |
