It is currently Wed Jul 09, 2025 11:25 am
Reply to topic  [ 26 posts ]
 GPS/fishfinder location
Post GPS/fishfinder location
Just wondering if any of you guys have a GPS/ fish finder on your mud boat? I wanted to know where the best location for the transducer would be? I have a hummingbird 597 HD, going on my prodigy 1854 hull. Thanks for your help
Sent from my LG-P870 using Tapatalk
Using Tapatalk
Wed Jun 18, 2014 11:30 am
Post Re: GPS/fishfinder location
I have an Alumaducer it is epoxied down to the inside of your boat near the transom. Some of the other guys have mounts either off the shelf or custom made that you can raise up and down either welded or mounted to the outside of the transom, and some have them attached to the trolling motor.
Wed Jun 18, 2014 12:28 pm
Lots of good post out there.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Wed Jun 18, 2014 12:38 pm
Wed Jun 18, 2014 1:39 pm
Yes sir mine works flawlessly. You have to prep the aluminum properly and make sure it is in a good spot and works at full speed and idle before you epoxy it down.
Wed Jun 18, 2014 2:05 pm
MMT Moderator
I used the Kayak Ram Mount and have not had an issue... It's aluminum and if you hit something it will bend & not break... I pull it out of the water before taking off on plane.
http://www.austinkayak.com/products/102 ... O9jDvw_wcB
GTB 1860 w/ 2019 GTR40XD-HO
Wed Jun 18, 2014 2:10 pm
Rob, what gauge aluminum is your boat?
Using Tapatalk
Wed Jun 18, 2014 3:42 pm
35 GTR chasin a BBC 1848
Wed Jun 18, 2014 3:49 pm
Wed Jun 18, 2014 3:52 pm
Wed Jun 18, 2014 3:58 pm
Will do.
Wed Jun 18, 2014 5:06 pm
What degree did you go with rob?
Using Tapatalk
Wed Jun 18, 2014 5:59 pm
I guess my question is what's the problem with using the one that came with the system and just screwing that sucker into the stern and using a marine grade silicone on the screws?
Using Tapatalk
Wed Jun 18, 2014 6:18 pm
Wed Jun 18, 2014 6:25 pm
Here is mine with the kayak ram mount
Wed Jun 18, 2014 7:30 pm
Icon, is that below flush of the boat? Does the water flow bend it back?
Using Tapatalk
Wed Jun 18, 2014 8:06 pm
Wed Jun 18, 2014 8:37 pm
It's a little below, you can cut and bend the aluminum rod to how you want. I do believe the water pushes it up a bit. I have noticed that it was working while under way, but now that I think of it, it wasn't last time I took boat out. I was just wanting something to flex if I hit something, so this fit the bill just fine. I was going to go with a mount that I could slide the transducer up and down, but knew I would remember to pick it up while underway.
Thu Jun 19, 2014 5:43 am
I have mine on the trolling motor, only time you need it IMO
Thu Jun 19, 2014 8:19 am
Thu Jun 19, 2014 8:21 am
Mine is GPS and it's nice to mark obstructions, waypoints, good spots on multiple lakes/rivers,etc
Using Tapatalk
Thu Jun 19, 2014 12:25 pm
1748 Prodigy with MB 4500 Black Death
Thu Jun 19, 2014 1:09 pm
I don't always have my Troller down when finding fishing spots. In the river for example we find a spot while idling and then anchor, never even put the Troller down.
Thu Jun 19, 2014 1:18 pm
I had my friend weld the adjustable bracket to my boat. Works good. I ordered it from Gator Trax.
-J
Thu Jun 19, 2014 3:21 pm
You could make a bracket that the transducer mounts to that you could just clamp to the back of the boat or just slip over the transom if you don't have a hunt deck. That way you can pull it up when your gonna be running in stumps or mud and veggies and not tear it up. I've been planning on doing this just haven't got around to it.
Thu Jun 19, 2014 4:24 pm
Good point
Using Tapatalk
Thu Jun 19, 2014 4:43 pm
Users browsing this forum: No registered users and 88 guests
