It is currently Tue Jul 08, 2025 7:10 pm
Reply to topic  [ 10 posts ]
 Need some input *warning mudbuddy question inside*
Post Need some input *warning mudbuddy question inside*
So I have a war eagle 1848 and just put on a 35hp mudbuddy. My question is, is it unusual to have to shim the motor up from the transom? I only put it in water once to see how it was positioned and ran before drilling the transom to mount it. I was getting a lot of splash back over the transom. I'm new to mud motors and am not sure where I had it trimmed to exactly but I did get in contact with mudbuddy and they confirmed I have a short transom hull and motor.
Should I wait to bolt it down? Maybe I just had it trimmed to low for the speed? Please give me some input. Thanks.
Sun Jun 22, 2014 5:37 pm
Post Re: Need some input *warning mudbuddy question inside*
Couple pics would help more than anything
Sun Jun 22, 2014 5:53 pm
im trying to post pictures but for some reason it wont upload.
Sun Jun 22, 2014 6:06 pm
Looks a little low (belt housing) might have to shim up a little bit. Did you ever get it to plane out?
Sun Jun 22, 2014 6:53 pm
Yes it's too low
Sun Jun 22, 2014 7:09 pm
Sun Jun 22, 2014 7:13 pm
I'd go an inch at a time till it stops spraying you, your trim should be able to compensate for some of the issue you have going on there
-Custom pool noodle
-stage 4 water wings
Sun Jun 22, 2014 7:26 pm
if the motor is trimmed wrong it will slash back correct? but if you can trim it to where it doesn't then its good?
Sun Jun 22, 2014 8:10 pm
With you have a low transom I would be real careful not to sink it if u slow down to quick. I would try and build the transom up! On my last war eagle drop transom with just a 3 cylinder suk on the back I would take on water easy when slowed down and it didn't way nothing like a sd
Sun Jun 22, 2014 8:18 pm
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon Jun 23, 2014 5:32 am
Users browsing this forum: No registered users and 112 guests
