iowahawks
 need some help
I have a 30 HP long tail that is not running right. Took it out and I could not keep the fuel in the fuel filter, the ball kept going soft so I had to keep pumping it to keep pressure. It would only do this in thick weeds, the motor ran fine in open water. Got home and replaced all the fuel lines running from the tank and the filter. Put new plugs in also. The motor still runs like crap when running threw weeds, sounds like its flooding almost. It only does this when the motor is working hard, runs great in the garage. Any ideas on what to try next???
| Sun Aug 17, 2014 10:44 am |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
 Re: need some help
Crazy question but is the vent open?
_________________ 23 swomp/ 1542 tracker
| Sun Aug 17, 2014 11:23 am |
iowahawks
 Re: need some help
Yes, tried vent open, vent shut, everything I could think of
| Sun Aug 17, 2014 1:01 pm |
tinman454
Joined: Mon Feb 07, 2011 10:47 am Posts: 732 Location: Ontario ,Canada, eh!
 Re: need some help
Chec the pick up it the tank. If the bulb is going soft it a prob down stream of that.
_________________ 08 35 mudbuddy, gator traxx 3 man hide.
| Sun Aug 17, 2014 1:11 pm |
Muddy ducks7
Joined: Thu Jun 05, 2014 3:12 pm Posts: 396 Location: Bama
 Re: need some help
Dose it have a fuel pump
| Sun Aug 17, 2014 1:32 pm |
iowahawks
 Re: need some help
I'm not sure if it has a fuel pump or not, its a 30 HP generac motor. I checked the spark plugs out today after trying to start the motor for a good 2 hours. They are dirty and smell like gas, so I'm getting fuel to the plug. It also just started backfiring bad.
| Sun Aug 17, 2014 3:55 pm |
iowahawks
 Re: need some help
This is what the new plugs look like after motor ran for a hour or so. Starting to think its the carb that is not delivering enough fule
| Sun Aug 17, 2014 6:59 pm |
Trousertrout
 Re: need some help
Like tin man said that is all that is left. Carb or pump
| Sun Aug 17, 2014 7:08 pm |
Muddy ducks7
 Re: need some help
Have you try cleaning the carb, have you done any mods to the motor
| Sun Aug 17, 2014 8:34 pm |
Muddy ducks7
 Re: need some help
Sound like the fuel pump diaphragm is dried up or has holes in it.
| Sun Aug 17, 2014 9:15 pm |
iowahawks
 Re: need some help
the motor has now been in the shop for 3 weeks. before I took it in we installed a electric fuel pump, and that did not fix the issue. The shop put a carb kit in it, new diaphragm fuel pump and still wont run. they ordered a new carb and as of now doesn't seem to be helping.
| Sat Oct 04, 2014 11:30 am |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
 Re: need some help
Replace the fuel tank...
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Tue Oct 07, 2014 5:41 am |
StevefromAR
 Re: need some help
Typically if the bulb collapses while the engine runs-that's either a pick up tube obstruction or a vent problem. If it gets soft while the engine runs its either a fuel pump problem or am air leak-meaning it's sucking air into the fuel line due to a crack or loose fitting or a hole.
| Sat Oct 11, 2014 5:21 pm |
Delta1389
Joined: Mon Jun 03, 2013 8:24 pm Posts: 310 Location: Morgan City, LA
 Re: need some help
May be a stupid question but did you replace the ball?
_________________ 35 GTR on an 1844 Sportsman Fab hull Build thread: viewtopic.php?f=6&t=57498
| Sat Oct 11, 2014 7:06 pm |
