dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Greased shaft and water came out: seals need changing?
What's your diagnoses and remedy?
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Sat Oct 11, 2014 7:32 am |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
 Re: Greased shaft and water came out: seals need changing?
Keep grease in it at let er eat!
Sent from my beeper
Sat Oct 11, 2014 7:48 am |
dguidry
Can't rely on West Monroe advice But, seriously, are there seals where the shaft joins to belt housing which could leak or is it more likely the shaft seals near the prop?
Sat Oct 11, 2014 8:22 am |
odass
Id say by the prop. I've seen almost all mb do that, that's why I liked to grease mine more often
_________________ Dead Fowl Custom 1954hd with a GTR
Sat Oct 11, 2014 8:34 am |
LA Prop
change seals mine was doing that during crawfish season and i waited like everyone said and i bought a new shaft cuz mine had a griooves cut in it from under the bearing sleeve
_________________ 20' homemade skiff with a stage 2 gtr
Sat Oct 11, 2014 12:33 pm |
Gigafowl
Sat Oct 11, 2014 1:22 pm |
Woodiebuster
Sun Oct 12, 2014 2:32 am |
Russ
New seals (and bearings). Water can't get to the shaft at the belt housing end unless there's water in the belt housing. So if the prop side isn't leaking, you got a leak in the belt housing that needs dealt with along with the seals. The drain in the bottom of the housing was leaking on mine, but a little silicon around the threads took care of that. And yes, there are seals at both ends of the shaft. More than likely prop end, though.
Sun Oct 12, 2014 10:18 am |
Gigafowl
Sun Oct 12, 2014 12:23 pm |
Woodiebuster
Go-Devils are still the seal eatingist motor out there
Mon Oct 13, 2014 4:24 am |
Russ
O.O Godevils have seals?!
Mon Oct 13, 2014 6:24 am |
dguidry
Thanks for the advice gentlemen.
Mon Oct 13, 2014 7:11 am |
T10
Joined: Wed Apr 10, 2013 10:53 am Posts: 257 Location: ETX
_________________ WC Custom 1854 huntdeck pushed by MB7000
Fri Oct 17, 2014 5:26 am |
Gigafowl
Sat Oct 18, 2014 6:40 am |
T10
Mon Oct 20, 2014 9:45 am |
