It is currently Mon Jun 30, 2025 1:17 pm
Reply to topic  [ 9 posts ]
 Trim Relays?????
Post Trim Relays?????
Can you get the dam things from Autozone or parts house.One of mine has gone out.....
Thu Oct 09, 2014 12:50 pm
Post Re: Trim Relays?????
does it have any printing on the relay? should be able to match up 12v relay pretty easy?
http://www.amazon.com/Parts-Express-Wat ... =12v+relay
Thu Oct 09, 2014 12:52 pm
Thats it!!!
Thu Oct 09, 2014 12:57 pm
That’s it as in:
1. That’s the part I need
2. That’s it I have had it with you fuckers!
3. That’s it I moving to Mud Motor elitist shat
4. That’s it I buying a Prodrive
Thu Oct 09, 2014 1:49 pm
Thu Oct 09, 2014 2:00 pm
#1 Brother thanks!
I'm going to run by Autozone and see if they got such though.....
Thu Oct 09, 2014 2:06 pm
The standard ones you see at the auto parts store, specifically the ones you can grab off the rack are probably only 20a relays. Most of the relays on trim systems are at least 50a and should probably be rated for more.
Fri Oct 10, 2014 11:32 am
MOST relays have the data and amp ranges printed right on them - and then if it's 2, 4 or 5 terminal
Fri Oct 10, 2014 11:44 am
If anyones needs one go to parts house they $17......
Mon Oct 13, 2014 7:09 am
Users browsing this forum: No registered users and 111 guests
