It is currently Fri Dec 19, 2025 2:03 pm
Reply to topic  [ 14 posts ]
 300lb 1848 alumacraft and a swomp 23
Post 300lb 1848 alumacraft and a swomp 23
I have an alumacraft 1848 riveted hull, 300lb empty was thinking of pairing it was a swomp 23, any info will help
Fri Oct 31, 2014 10:16 am
Post Re: 300lb 1848 alumacraft and a swomp 23
I would go bigger in the 35. I think your speeds will be very limited.
Fri Oct 31, 2014 7:13 pm
I agree, get more horses! But that 18 will run better than a shorter hull. even with a 23. I wish they still made that configuration... I can get by with a lighter weight riveted hull, and that would cost a lot less than a custom hull.
Sat Nov 01, 2014 3:44 am
Thanks for the info I was concerned about the weight of the 35 on the riveted hull
Sat Nov 01, 2014 4:59 am
I have a Swomp 35 on the same size boat. It carries that motor just fine. Get the 35. Just my 2 cents.
Sat Nov 01, 2014 6:21 am
1848 has the same displacement regardless of whether it all welded or riveted. Go with the 35. That size boat is perfect for it. Going any less and you cheating yourself.
Sat Nov 01, 2014 7:32 am
The only question is that transom height- on the Alumacraft site- yes, they make one but with a 20" transom- this will problematic with a 35 LT (or any 72" length) and you will have to strain to keep that prop in the water. One fit is the 35 BackH20, because of its additional adjustments the others don't have.
I know a friend who has an old Seanymph 1852, also riveted, who finally cut down the 20" transom to 16" and it made a world of difference...he currently has a 35 MB Hyper on it and it scoots but the shorty has had a bunch of repairs.
Let us know how it goes!
Sat Nov 01, 2014 7:53 am
Thanks again for all the reply, the transom is 16 with 20''sides and it's rated for a 40hp, but the 40 ob that was on it only weighed 140 vs 225 that the 35bw weighs, looks like I'll give it a shot, the 35bwlt cost the same as the 23 hp copperhead i was looking atif I wwent that way
Sat Nov 01, 2014 3:08 pm
I run a GDLT Honda GX630 (20-22hp) on a rivited Alumacraft 1848 with a 20" transom. I have to bend the cav plate up some but it runs fine. I can get 16 mph with my bowfishing stuff. I thought about cutting the transom down but I don't need speed where I go
Mon Nov 10, 2014 7:35 pm
Was out this past weekend in a friend's boat, a heavy 1852 with a 20'' transom and a old 25 mb lt, with two of us and hunting load we average 17.3 bumped 18 in shallow water, trying to get him to let me put it on my boat to see what it will do, but he's not going for it yet
Wed Nov 12, 2014 4:42 am
I have a 35 Backwater on a 17-52 Alweld, had I bought anything smaller I'd always be looking to upgrade to the 35. Always max out your HP on toys. Performance is better with more power, resale is better and it costs less to buy the biggest the first time rather than stepping up the HP ladder a few buck at a time.
I've never heard of anyone changing something up because it had too much power or was too fast, think about it.
35 Swomp on a 17-52 Alweld on a crusty old trailer you probably shouldn't follow too close
10hp Swomp lite 14-36 alumacraft
Wed Nov 12, 2014 12:34 pm
i had a swomp 35 and the motor weight is more over the transom to slightly forward than hanging off the back like an outboard you shouldn't have a weight problem my 35 was on a 18x46 and did fine hope it helps
Thu Nov 13, 2014 2:34 pm
Thanks again for all the info, much appreciated, now there is talk here about hp restrictions may be coming to certain areas
Fri Nov 14, 2014 4:59 am
smaller HP Decal kits usually work for horsepower resrictions :lol:
Fri Nov 14, 2014 9:33 am
