It is currently Mon Jun 30, 2025 4:09 am
Reply to topic  [ 23 posts ]
 Help cutting out Bench seat
Post Help cutting out Bench seat
Alright guys so I have a 2000 sea ark boat and it has a bench seat on the back that is really just in the way for me. I want to cut it out and I can just sit on the back pod when I need to sit down. I'm thinking I can just cut it out with a grinder and a cut off wheel and grind down the aluminum where it meets the edges of the boat. Do ya'll think that I'll loose some support by cutting it out? I really want it go so I can stand up and drive. Anybody done this before?
P.s. also theres some holes under the seat and I'd like to have it out and patch the holes from the inside of the boat
1548 SEA ARK with 2014 GTR 35
02 DURAMAX- MORE POWER, LESS SMOKE
Tue Nov 04, 2014 7:55 pm
Post Re: Help cutting out Bench seat
Cut it out and get it out of you way.
Tue Nov 04, 2014 8:17 pm
You will need something to brace the end where cut it off. Best thing to do is put a piece of metal to cover it up. Or put angle around it to have some storage. I've done it both ways.
Sent from my beeper
Tue Nov 04, 2014 8:21 pm
Looks good
Tue Nov 04, 2014 8:24 pm
Looks good I have just a wooden false floor but I guess if I need to I can take it to a welding shop and get another rib put in it. Here's the boat
Tue Nov 04, 2014 8:40 pm
To make up for the foam I'm loosing should I put some under the false floor?
Tue Nov 04, 2014 8:43 pm
Tue Nov 04, 2014 9:13 pm
Cut it out and run it. I removed 2 benches from my 1648 and it is very rigid.
Tue Nov 04, 2014 9:24 pm
Tue Nov 04, 2014 9:25 pm
What size motor you got on it
Wed Nov 05, 2014 10:09 am
Wed Nov 05, 2014 10:20 am
Well I got started today and I'm not gonna lie it's a little nig rigged mainly cause I can't weld and I'm planning on getting a new boat soon anyways. Gonna finish up either tomorrow or Friday
Wed Nov 05, 2014 7:11 pm
Wed Nov 05, 2014 7:12 pm
That's not bad at all considering you mentioned you can't weld. One thing you could do being you can't weld, is try and find some scrap aluminum, or tin or a beat up ass street sign or something, and pop rivet it over the foam so it doesn't break up and be everywhere. Paint it, and should be good to go.
Thu Nov 06, 2014 5:57 am
if my calculations are right if you were to remove the bench to just have a driving pod you should be able to use the aluminum from the top of the bench seat to place on the floor and have plenty left over so there would be no need to buy aluminum.
Thu Nov 06, 2014 7:02 am
Thu Nov 06, 2014 7:11 am
Well I'm going with what I know how to do easily, I cut out wood and covered them in carpet like the rest of my floor and I'm going to use that to cap it off and extend the floor. I'm just waiting on the flex seal to dry where I had some small leaks
Thu Nov 06, 2014 8:38 am
Sent from my tree stand
Thu Nov 06, 2014 9:17 pm
Got it all finished up. Of course I bought the wrong thickness of plywood so there's a little step up but it really shouldn't be an issue. Everything I did costs less than $30. I'm pretty happy with it so I guess that's all that matters
Fri Nov 07, 2014 10:22 am
Not bad.
Fri Nov 07, 2014 6:54 pm
Be allot easier to drive like that, good work
Sat Nov 08, 2014 12:53 pm
better than most, good job.
1748 Cottonmouth Hybrid Custom with a 2015 35GTR
7 yr old Boykin Spaniel
One Badazz wife that that hunts like a champ
ROLL TIDE!!
Sat Nov 08, 2014 1:04 pm
Thanks y'all. Going out tomorrow to test it out
Sat Nov 08, 2014 3:31 pm
Users browsing this forum: No registered users and 112 guests
