COONA$$CRAKA
 Inboard mudboat, need help
I am wanting to build a 8-10' fiberglass motorize pirogue with a 2.5-5hp motor. I need some help finding the drive system(stump jumper, packing box, steering, etc.) for it. I live in Metairie, LA so if any of my fellow coonasses could help, I'd appreciate it.
_________________ 35hp GDSD/ 1848 Custom New Orleans, LA
Sun Nov 30, 2014 9:26 am |
brycecheramie
 Re: Inboard mudboat, need help
Sun Nov 30, 2014 10:41 am |
cootshoot
Fri Dec 05, 2014 2:56 pm |
Marshgator
Try these and good luck.
Ullo's Hardware-Dept Store 4701 W Bank Expy #4 Marrero, LA 70072 Phone: (504) 341-8512
Alario Bros Commercial Fishing & Marine Supplies, Inc. 894 Avenue A Westwego, LA 70094 Phone: (504) 341-1843
Tue Dec 09, 2014 11:16 am |
Capt. JJ
Alario's will have everything you need to put it together, stuffing box, flange bearings if you go that route, and the rudder box, but your going to have to build your shaft log or stump jumper and get the shaft made. I've built a bunch of them, and I can't think of anywhere where you can just go buy a stump jumper/strut set up to throw in the boat, it will need to be built.
Check out La Sportsman, you will often seen people selling the running gear and strut set ups from mud boats on there. Last one I built I bought my shaft wheel and clutch off of sportsman for a deal.
Justin
Tue Dec 09, 2014 1:32 pm |
redlined_b16a
If you have acess to a torch and welding machine a simple steel set up is pretty easy to make out of 1 1/4" pipe, a cutlass bearing for the bottom and a rope packing at the top.14 degree angle.I have never seen a factory made.
Mon Dec 22, 2014 6:23 am |
redlined_b16a
Mon Dec 22, 2014 6:24 am |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
8' to 10' pirogue...you must be a little bitty fella. I'd go at least 15',
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Mon Dec 22, 2014 8:36 am |
latravcha
_________________ Aucoin 20X48 36pd Lock your wife and your dog in the garage for an hour. Then open it and see who's happy to see you.
Mon Dec 22, 2014 11:04 am |
redlined_b16a
once motorized it will have to be inspected and and registered with numbers,unless your on private property.In Louisiana anyway.
Mon Dec 22, 2014 11:41 am |
COONA$$CRAKA
I saw that pirogue for sale already. I have a 14' but Id rather go smaller and lighter, so I can throw it on my mounts on my boat. This is going to be use to pick up ducks and decoys. Im not looking to go fast and I dont want a trolling motor. Im thinking at most, a 10' boat with a 2' bottom at the widest. Ill make the boat out of fiberglass covered foam. if I have to Ill make a flat back and run the shaft out the transom. What do you think, possible or not so much?
Fri Jan 02, 2015 11:53 pm |
COONA$$CRAKA
Fri Jan 02, 2015 11:55 pm |
Marshmaster45
Joined: Sat Nov 26, 2011 5:01 pm Posts: 355 Location: larose,la.
Gonna be a bit squirrelly .
Sat Jan 03, 2015 5:02 am |
