It is currently Fri Jun 27, 2025 8:33 am
Reply to topic  [ 22 posts ]
 longtail
Post longtail
When is a longtail better then a surface drive ? I am getting a new motor and never own a longtail just thought i would ask thanks for any input..
Sat Nov 15, 2014 5:33 pm
Post Re: longtail
Shallow water with a hard bottom and cypress/tupelo swamp. Also, anytime your crossing logs and get high centered.
17*38 Klibert 23GDLT
Sat Nov 15, 2014 6:56 pm
Post Re: longtail
What da go get'er said., plus, you are the type of hunter that gets up earlier than most; you enjoy the ride not necessarily speed; you still have a rotator cuff; your idea of reverse is a good stout pushpole; you take sides, neutral is a no-no; you can always say "my shaft is longer than yours"; you are on tight budget and your wife has said no to a surface drive upgrade for the past two decades; you fancy yourself the master of a glorified lawnmower engine and enjoy driving standing up; you fancy yourself Bigfoot of the swamp and need a prop; you have limited mechanical skills and your reigning philosophy is KISS (keep it simple stupid); you are a stubborn s.o.b.... :mrgreen:
Sun Nov 16, 2014 6:33 am
Post Re: longtail
:lol:
Sun Nov 16, 2014 7:29 am
Post Re: longtail
Is a long-tail faster or slower ?
Sun Dec 21, 2014 10:22 am
Post Re: longtail
Slower. Longtails are direct drives. 1:1 ratio. Most surface drives are around 2:1.
Sun Dec 21, 2014 10:27 am
Post Re: longtail
Long tail is the 4x4 of the swamp! Did deeper, has farther reach, has more turn radius when stuck, easier on shoulder, way cheaper on the pocket book!
Sun Dec 21, 2014 11:35 am
Post Re: longtail
18x40 skiff/35 hp GTR
Sun Dec 21, 2014 5:27 pm
Post Re: longtail
Sun Dec 21, 2014 6:32 pm
Post Re: longtail
Sun Dec 21, 2014 7:28 pm
Post Re: longtail
Sun Dec 21, 2014 7:41 pm
Post Re: longtail
We run in hard bottom not a lot of mud . We also run 75/25 shallow deep . I was just trying to get things right this time :lol: Can you mod a long tail like u do a surface drive
Sun Jan 04, 2015 11:13 am
Post Re: longtail
Lt is better for shallow hard bottoms, as for modding yes but being a 1:1 drive you won't gain speed but load caring ability will rise
Sun Jan 04, 2015 6:20 pm
Post Re: longtail
Long tails are outstanding for many things but lack diversity. You can own a surface drive and it will do just about anything you want. It has the speed and ability to travel a long distance with out wearing you down.
40HP Gatortail
Sun Jan 04, 2015 7:33 pm
Post Re: longtail
Mon Jan 05, 2015 10:23 am
Post Re: longtail
17'Extreme Metal Fab. Skiff - 23 GDLT
Mon Jan 05, 2015 6:15 pm
Post Re: longtail
Ran a long tail for years and recently changed to a surface drive. So far I can not find one reason why I should miss the longtail. Unless, you count the cost because you can definitely pick up a nice used longtail for a heck of a lot cheaper than a SD.
If my LT was a 4x4 then the SD is a 6x6 with tracks because I go places I never thought of going before faster and easier!
Mon Jan 05, 2015 6:21 pm
Post Re: longtail
Schmidty, sd gears are smaller on top larger on bottom as you said. if you have 1.5:1 gearing, the prop turns 1 revolution to 1.5 revolutions of the engine. Hence the 1.5:1. So you can turn a bigger prop but slower(assuming a standard rpm). And yes about modding an lt. You can add more power to go up in pitch/dia on a prop, but it will take more to go up a pitch and turn it the same rpms as a size smaller because of the direct drive
Sun Jan 11, 2015 10:08 am
Post Re: longtail
Sun Jan 11, 2015 10:17 am
Post Re: longtail
Never mind, is see what your running.
Sun Jan 11, 2015 10:20 am
Post Re: longtail
It has been said before but bears repeating- the surface drive is a better fit in most areas and as an upgrade, one should never have to go back to an LT. That said, in marshes with little water and hard bottoms ( little mud, no beaver dams, etc.) the LT shines- only outshined by an airboat...but those get very expensive to own and maintain and will get stuck too. I was hunting by myself last time out, fairly stiff breeze, and picking up decoys was made complicated but I've been using one long enough that I could trim and feather my 27 HP LT and make relatively short work of picking them up. For heavy loads and long distances a surface drive is the ticket and there expensive mods pay some dividends...I would not waste money on mods for my LT. It is not built for speed but it is a very reliable hunting tool. I usually hunt 2 at most in my boat, the distances are not long, and speed is not essential. I cannot justify nor want the expense of a surface drive. I apply any "mod" money to shotshells, hunting gear, and libation. My wife and I were at the store yesterday and I pointed to the Yeti cooler and told her I could buy another good quality pump for that price; my wally world improved Coleman cooler is doing fine. :mrgreen:
Sun Jan 11, 2015 4:48 pm
Post Re: longtail
Mon Jan 12, 2015 10:54 am
Users browsing this forum: No registered users and 54 guests
cron
