It is currently Wed Jul 02, 2025 10:39 am
Reply to topic  [ 19 posts ]
 fuel filler cap for deck
Post fuel filler cap for deck
I posted a topic earlier about brother breaux boats but are they all the same size hole? I need to order one asap so I could overnight it. any help is appreciated
1650 express w/a 60 jet
Mon Jan 12, 2015 12:30 pm
Post Re: fuel filler cap for deck
Don't know about yours but my tank has 1.5" od filler neck. It was built by someone else though. 1.5" is probably standard but who knows what brother uses.
Mon Jan 12, 2015 12:34 pm
he's a tough bastard to get ahold of lol
Mon Jan 12, 2015 12:59 pm
Might be easier to buy tape measure :D:D:D
- Mark Twain
Mon Jan 12, 2015 2:35 pm
its a 1.5"
http://www.cpperformance.com/p-283-bill ... fills.aspx
1854 Brotha Breaux chased by 36 PD!
Mon Jan 12, 2015 2:46 pm
thanks hearse... :lol: I just didn't wanna drill it out and and be left without a cap. I cant unscrew it because its riveted in or ALL the bolt heads broke off at one point lol
Mon Jan 12, 2015 3:14 pm
Might have nuts on the bottom.
Mon Jan 12, 2015 3:17 pm
how TF do I get to those? :shock: :shock:
Mon Jan 12, 2015 3:23 pm
Man take a picture of what you're working with..lpl
Mon Jan 12, 2015 3:26 pm
heres what I got fellas
Mon Jan 12, 2015 3:52 pm
That's rivets. Get a drill bit that is slightly smaller than the head of the rivet. Drill till the head pops off. It'will start to spin when the head pops off. Then jus hit what's left with a philip screw driver an hammer.I
Mon Jan 12, 2015 4:20 pm
Why you taking it out?
Mon Jan 12, 2015 4:21 pm
the reason I haven't done that yet is because it will drop it in the tank and then im not sure how to get it out. the cap is boogered up and I cant get it to spin anymore
Mon Jan 12, 2015 4:26 pm
The rivits will not fall into the tank. I just installed the same one in my boat. Can you not look under there.
Mon Jan 12, 2015 4:29 pm
ill have to look when I get back to the house. I had a friend take that picture for me. thanks for the help! Ill let you know what I end up doing
Mon Jan 12, 2015 4:34 pm
u can loosen the nut on the underside of the cap and it will prob let u turn it. No the rivets wont fall out if drilled. Theres a hose clamp on the bottom side of deck ext. if loosening the nut doesn't fix ur issue, drill out the rivets, loosen the clamp and pull out the old fuel fill, drop a new one in, tighten clamp, only put back 2-3 rivets. I helped Joe install that one, got the same one, he riveted the shit outta his! lol
Mon Jan 12, 2015 4:51 pm
yea they're all in there lol. I took the nut off the bottom and its still stuck.
Mon Jan 12, 2015 5:01 pm
Call the company ans see if you can just get a new cap. No need to replace the whole thing.
Mon Jan 12, 2015 5:05 pm
decided to mess with it one more time before I drilled the rivets out and soaked it in some free all for about 20 minutes. of course it had to be the last time that I was gonna fool with it that it decided to free up and all is well now!
Wed Jan 14, 2015 1:32 pm
Users browsing this forum: No registered users and 116 guests
