It is currently Thu Jun 26, 2025 2:28 pm
Reply to topic  [ 8 posts ]
 adding beavetaol pods to a polarcraft 14x76
Post adding beavetaol pods to a polarcraft 14x76
I am running a MB 25 LT and am looking for more performance out of my rig and am adding med beavertai lpods to my boat. I was wondering if anyone had done this and if so what am I getting into? I am wondering if I should just take to a machine shop and have them put on? I was told about $60.00 per weld wich seems fair. any advise on this would be great. P/S I am 295 soaking wet so with hunting gear and waders well over 325. so I have alot of weight in th ass end of this boat.
Tue Dec 30, 2014 12:12 pm
Post Re: adding beavetaol pods to a polarcraft 14x76
I made pods for a fiberglass boat I had. My issue was that my motor was to heavy for the boat, and it was dangerous coming down off a plane. I used similiar specs and dimension of the beavertail pods using their CAD drawing. I was able to offset about 400lbs of weight with the pods. My boat sat level in the water and jumped on plane quicker. If your boat isnt very wide, the pods may not help too much. But they will definitely help if your just having a problem with weight in the rear end.
1754 GTB w/ JBP stage2 GTR
Sun Jan 11, 2015 8:05 pm
Am I reading this right? Your boat is over 6' wide on the bottom but only 14' long? Are you sure your not measuring the beam? A short wide boat is a recipe for bad performance with a longtail.
Mon Jan 12, 2015 11:03 pm
Best thing you can do is move some weight to the front of the boat
Mon Jan 12, 2015 11:16 pm
I put some beavertai pods on mine set about 2" higher in the back
Mon Jan 12, 2015 11:23 pm
Wed Jan 14, 2015 9:13 am
I would try moving battery and/or gas to the front for starters and see what that does performance wise. It was a game changer in my 1448.
Backwater Swomp 23 / Lowe L1448M
Thu Jan 15, 2015 3:45 pm
holy sweet baby jeebus! 14x76 would be like 2 14x36's welded together plus a couple inches! that fucker must look like a box!
Fri Jan 16, 2015 1:45 pm
Users browsing this forum: Majestic-12 [Bot] and 56 guests
