It is currently Thu Jun 26, 2025 2:14 pm
Reply to topic  [ 21 posts ]
 25 Kohler swap
Post 25 Kohler swap
Looked everywhere can't find out which engines are compatible with a GD LT that came with the 25 horse Kohler. Looking to go as big an engine as I can with this frame. Don't currently have the motor so I can't look at the frame to see what the SN says if Anyone knows it would be a great help.
Fri Dec 26, 2014 10:12 am
Post Re: 25 Kohler swap
I think the generac has the same footprint and shaft height. You can make others work with some modification.
Fri Dec 26, 2014 10:43 am
Fri Dec 26, 2014 10:55 am
Post 25 Kohler swap
Gt990 or 999, 33-40hp
You can go to a big block briggs or kohler or something else but the shaft height and foootprint are gonna be different so it will require some modification. The 30hp kohler is also the same exact block so you could build yours up or do a direct swap with one of those too.
Fri Dec 26, 2014 11:00 am
Fri Dec 26, 2014 11:11 am
With no modding, u can go up to a 27 (small block).........
Fri Dec 26, 2014 1:57 pm
The 30 is the same block, and the generac is the same size and pretty sure the correct dimensions.
Fri Dec 26, 2014 1:58 pm
Fri Dec 26, 2014 2:12 pm
Look it up. Fairly certain the 33 and 40 are same block. Look up the shaft height for your motor, then look at the shaft height for whatever you're thinkin about using. That will be the most important part for you to overcome. I'm also nearly certain they use the same mounting pattern, but that can be easily overcome.
Fri Dec 26, 2014 2:47 pm
Fri Dec 26, 2014 2:55 pm
You will, but the generac isn't really a "big block", if you are interested in that one. Look on kohlers website at specs, then look at generacs. Shaft height is going to be your main obstacle.
Fri Dec 26, 2014 3:18 pm
Kohler looks to be 4.46"
Still lookin on the genny
Fri Dec 26, 2014 4:21 pm
Fri Dec 26, 2014 4:40 pm
Doubt it bro, is yours a ch730?
Fri Dec 26, 2014 7:13 pm
Fri Dec 26, 2014 7:41 pm
http://www.ebay.com/itm/Subaru-40hp-64l ... 3a9328640e
http://www.kohler-engine-parts.opeengin ... rawing.pdf
Actually looks like the kohler may be a cunt hair taller. I think you could make it work though.
There's a drawing in the ebay link, in the pics.
Fri Dec 26, 2014 11:38 pm
Sat Dec 27, 2014 6:44 am
got this thing off my friends new boat the other day, the motor runs pretty strong but havent had it in the water yet. im fully expecting that once i get it on my boat im gona be wanting more power. Any way of telling what model this engine is? ive read a lot of the 25 kohlers cant be honed bc they some nickel silicone coating in the cylinders. also how much power could i expect with it bored 25 over? would it be worth it?
Fri Jan 02, 2015 6:17 am
I actually came on here to ask a similar question. I have a 20hp kohler beavertail. Yes 20hp kohler not 27hp....they did make them. I am looking to get more hp. Would a kohler 27hp or 30hp bolt right on? I think they are the same block but I might be mistaken.
Sat Jan 17, 2015 11:34 am
Don't think so. The 20's are a smaller engine. You will likely have to do some modifications.
Sat Jan 17, 2015 11:35 am
If I'm reading that correct 18-30hp have the same specs..... But everyone is telling me they don't. Am I stupid? Lol
Sat Jan 17, 2015 12:51 pm
Users browsing this forum: Majestic-12 [Bot] and 47 guests
