It is currently Sat Jul 12, 2025 4:46 pm
Reply to topic  [ 13 posts ]
 Dixie mud motor parts?
Post Dixie mud motor parts?
buddy of mine has a 23hp Dixie and needs parts. And the company is no longer in business. He needs bearings, seal and Shaft. anyone no where to get these or what his options are?
Wed Jan 28, 2015 8:00 pm
Post Re: Dixie mud motor parts?
better go to a bearing shop and match it. Local machine shop can build a shaft.
Wed Jan 28, 2015 8:07 pm
that is a option... just didn't know if there was a go to place...
Wed Jan 28, 2015 8:14 pm
Machine shop for shaft. Amazon for seals and bearings
Wed Jan 28, 2015 10:25 pm
What type and size of bearing I can't seem to get my lower unit apart to pull them out but the bearings seem like they are making a awful noise and want to replace them
Wed Feb 18, 2015 12:26 am
Not sure what year motor, but it should be a 1in shaft tapered to 7/8 on both ends. One end threaded and one end tapered with keyway for pulley/taperlock bushing. If it is a 7/8 shaft, have the bearing caps on both ends cut to fit seals on both ends. Dixie only had one seal on the prop side. It is notorious for leaking water and ruining bearings. I had my bearing caps cut to fit a seal on each side of each cap for a total of 4 seals. Then filled entire outdrive tube with grease. I had my shaft cut to match the original one but went with stainless.
seals: http://www.amazon.com/gp/product/B008E7 ... UTF8&psc=1
bearings: http://www.vxb.com/page/bearings/PROD/inch/Kit7485
should be able to find bearings cheap on ebay
Wed Feb 18, 2015 12:34 am
Mines a 2014 had the motor a year with 9 hours on it and it does drip water out the tail end just can't seem to figure out how to get the lower gear off and prop off to get them damn bearings out to check or replace thanks for your input as well I'm in Washington state and hardly a soul up here with a mud motor of any sort or help besides rummaging though MMT for info on repairs and such
Wed Feb 18, 2015 1:00 am
Prop you can take a rubber mallet and knock it off the shaft. Lefty loosey. To get the tail shaft off you'll have to loosen the motor bolt from the frame to lean it backwards and allow slack in the belt. Remove the belt off the upper pulley. Take off the nuts holding the tail shaft on. Use a putty knife to try and loosen up some of the RTV holding the tail shaft on and should come right off
Wed Feb 18, 2015 3:10 am
You should take the prop off before you pull tail shaft off. If you didn't you will have to find a way to hold the gear and hit the prop with a dead blow or rubber mallet. The gear comes off by removing the two screws in the gear and putting one screw in the open hole tighten down and the gear will slip off.
1754 prodigy- stage 2 GTR
Wed Feb 18, 2015 7:30 am
i put the screw in there but it doesnt come out looks like it has a key way holding it in maybe drill it out?
Wed Feb 18, 2015 12:02 pm
No don't drill. Ck you pm
Wed Feb 18, 2015 1:55 pm
https://www.youtube.com/watch?v=RBjtuetw44Q
heres a video on the taper lock bushing removal
Wed Feb 18, 2015 1:59 pm
Wed Feb 18, 2015 4:00 pm
Users browsing this forum: No registered users and 98 guests
