It is currently Mon Jun 30, 2025 2:15 am
Reply to topic  [ 14 posts ]
 Pro Drive prop removal
Post Pro Drive prop removal
I need to replace the lower unit seal nut on my Pro Drive. In reading the owners manual, it says to use a prop wrench. This looks like a piece of 2 or 3" aluminum flat strap with a hole in one end.
I don't have one of these. Is there a quick easy substitute for the wrench? Could I not just buy a piece of aluminum and drill a hole in it?
Thu Feb 05, 2015 5:50 pm
Post Re: Pro Drive prop removal
yes or a flat piece of metal will work.
Thu Feb 05, 2015 6:27 pm
Aluminum will bend. Get a piece of steel flat bar.
-Custom pool noodle
-stage 4 water wings
Thu Feb 05, 2015 6:30 pm
Thu Feb 05, 2015 6:31 pm
I a also trying to figure out, you remove the prop nut, why do you need a wrench to remove the prop. It isn't threaded onto the prop shaft is it?
Thu Feb 05, 2015 8:02 pm
Yes the prop is threaded on the shaft. You just changing props?
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Thu Feb 05, 2015 8:10 pm
No. He's replacing the lower unit seal nut.
Thu Feb 05, 2015 8:43 pm
Wow missed that Russ. Thanks.
I wanted to mention that the prop nut seal has left handed threads!
Thu Feb 05, 2015 9:18 pm
Thu Feb 05, 2015 10:46 pm
no bushing is not threaded. it's tapered and should most of the time come off with the prop then just take a pliers and squeeze it a little and it comes out. make sure to put marine grade anti sieze on everything prop shaft and bushing when you put it back together.
1856 Phowler commercial hull with extra flotation so I can run shallower. Pushed by a stock Prodrive until my wife gives me more money
Fri Feb 06, 2015 1:10 am
Where do you get marine grade anti seize?
Fri Feb 06, 2015 7:58 am
2x4 with a hole drilled in it works fine for me.
Fri Feb 06, 2015 9:19 am
A week BEFORE prop removal, spray some quality penetrant oil at front and back of prop. It will save a lot of cussing.
I always used a 2x4 with hole drilled in it.
Most auto stores have marine grade anti-seize . Or just eBay it a week ahead of time.
Helps to remove prop I ce every year, needed or not.
Gen. 3 lower unit is much better since they dropped thread prop BS.
Fri Feb 06, 2015 10:10 am
This worked for me. Wouldn't budge been on there for 3 seasons. Had this made, she came right off.
1848 GTB, 36 PD w/ FPR
Fri Feb 20, 2015 11:31 am
Users browsing this forum: No registered users and 162 guests
