It is currently Sun Dec 21, 2025 5:55 am
Reply to topic  [ 28 posts ]
 Cavitation problem. Backwater 35
Post Cavitation problem. Backwater 35
I have a backwater 35 ss on my grizzly mod v 1648. At low speeds I can handle the boat no problem but I am unable to get halfway through the rpms without the motor jumping out of the water. I used both of the shims with no luck. The water coming off of the boat is peaking right at the front of the cavitation plate. If I add pods to the boat will this help with this situation. I have started talking with jake at backwater and am hoping to switch the mount to the ls to help. Any other suggestions.
http://youtu.be/a8rXq6I_48Y
Sun Mar 01, 2015 8:15 pm
Post Re: Cavitation problem. Backwater 35
Hope you get it sorted out- I have the same hull (2004) and plan on putting the same motor on it. I've had to bend the cavitation plates on both GD and MB longtail motors on it, but this Backwater SS is a different animal. :mrgreen: At least the BW affords you more adjustment points. I also benefitted from putting the battery and a few other items in the bow storage section.
Mon Mar 02, 2015 12:19 pm
Me to I can force the motor under and it runs like 27 mph so if I can't get it to work like it should I'll be a happy guy. I am definitely impressed with backwaters product just having adaptability problems.
Mon Mar 02, 2015 12:43 pm
27 mph with a longtail?
Mon Mar 02, 2015 12:47 pm
18x40 skiff/35 hp GTR
Mon Mar 02, 2015 12:52 pm
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Mon Mar 02, 2015 1:03 pm
This was Saturday.
H Finn
BACKWATER PROSTAFF
Mon Mar 02, 2015 1:05 pm
How is it that a prop turning on the end of a stick an awkward angle with the same exact motor as any other brand can be faster?
Mon Mar 02, 2015 1:08 pm
Well, I'm turning a. 9x7 wheel on a 23 hp , mikuni , bps crossover, cam, setx heads . It scoots and my rig is about perfect for a longtail of that size 15x36 . It must be the gatorglide. :lol:
H Finn
BACKWATER PROSTAFF
Mon Mar 02, 2015 1:11 pm
Mon Mar 02, 2015 1:34 pm
Mon Mar 02, 2015 1:36 pm
Mon Mar 02, 2015 1:45 pm
Mon Mar 02, 2015 2:23 pm
Mon Mar 02, 2015 2:44 pm
Probably an easy adjustment. Just need to toy with it or call Frank
40HP Gatortail
Mon Mar 02, 2015 3:32 pm
I'm gonna play with moving the weight around in my boat. Probably add pods and shorten my transom. It's just over 19 inches. And my speedometer definitely said 27.
Mon Mar 02, 2015 4:02 pm
40HP Gatortail
Mon Mar 02, 2015 4:44 pm
40HP Gatortail
Mon Mar 02, 2015 4:45 pm
I've been talking with jake from backwater from the start. It's a combo of my transom height and weight. Fixed with pods and lowering the transom
Mon Mar 02, 2015 4:57 pm
Pods are a bandaid for an improperly rigged boat.
i.e. You got too much motor on your boat.
Mon Mar 02, 2015 5:04 pm
I like my boat and my motor. So a permanent welded bandaid it is lol
Mon Mar 02, 2015 5:09 pm
He's got an SS frame on a tall transom boat. Cutting the transom down to 16" will get him fixed.
Mon Mar 02, 2015 5:12 pm
Mon Mar 02, 2015 5:29 pm
I thought the ss backwater motors had enough adjustment to work on both the tall and short transoms and the same for the standard length ones as well?
Mon Mar 02, 2015 5:33 pm
Mon Mar 02, 2015 6:05 pm
I agree with you. I know that mud motors on my are not ideal on a mv but anyone who goes across Kissimmee for a morning hunt then is faced with a 7 mph head wind on the ride home across that lake would definitely understand why People use them. I don't run mud flats or jump beaver dams. I shove myself in and out of the weeds and run through hydrila
Mon Mar 02, 2015 7:41 pm
Kissimmee can be very dangerous at times and whenever the wind is blowing I try to use the pig trail and hug the north shore as close as I can . That being said we went from point a to b in a gdsd 1660 with a gdsd 35 and it wasn't bad at all.
Mon Mar 02, 2015 8:36 pm
I believe you, Huck and Frank! For all others, there is a Predator underneath all the Backwater motors! Vroom, vroom! :mrgreen:
Tue Mar 03, 2015 7:59 am
