It is currently Sat Jun 28, 2025 12:44 pm
Reply to topic  [ 47 posts ]  Go to page 1, 2  Next
 LED strip lights
Post LED strip lights
Where are yall mounting them and how many? I bought some that are like 21" long. I've got some ideas just wondering what everybody else is doing.
Wed Jan 21, 2015 2:20 pm
Post Re: LED strip lights
i mounted ones a lot longer thn that under my catwalks.
1748 Prodigy with MB 4500 Black Death
Wed Jan 21, 2015 2:24 pm
If you haven't opened them and can send them back, do. Ching chong on Ebay has a 20 ft strips for something like $10. Get you a couple of those and you run them around the entire gun rail. Just an idea.
2014 Prodigy 1748 V-Rake 21" sides, Fish-Tail Design, 2 Rear Half Boxes, Catwalks with treys, front deck with hatch, and being ran by a MB Black Death 4500
Wed Jan 21, 2015 3:00 pm
Yeah I haven't opened them and I saw those long ones that you can cut
Wed Jan 21, 2015 3:10 pm
I used the 21" strips as well it took me 7 to do mine and I put them under the catwalk and front deck. I just soldered the strips together make a longer strip. yes the 20ft strip would of been the easiest route to take and would eliminated a lot of the soldering process but that only took me about 15 min to do.
1754 hybrid huntdeck 35gtr
Thu Jan 22, 2015 8:20 am
I got a 16' role of of Amazon for like $15
Thu Jan 22, 2015 2:33 pm
X2 on the 16 ft amazon ones.
1854 Uncle J pushed by a gen 3 PD
Thu Jan 22, 2015 2:36 pm
Thu Jan 22, 2015 2:39 pm
Fri Jan 23, 2015 7:41 am
:lol: no just from bitterness of being launched from there for bitching about every thread being a bitch about this place or Dean - bunch of red neck pecker woods
Fri Jan 23, 2015 7:44 am
18x48 War Eagle 35 GTR "Fatback Cadillac"
Fri Jan 23, 2015 7:48 am
These are the 16' strip off Amazon I cut it in the middle
Fri Jan 23, 2015 7:49 am
the Amazon led strips are pretty easy to work with - they cut clean and use a little silicone to secure in place - I used door bell wire to wire them in,
Fri Jan 23, 2015 7:56 am
Has anybody had both red and green, for comparison?
Fri Jan 23, 2015 11:16 am
Red white and blue all at one time would be sweet...:lol:
Fri Jan 23, 2015 5:51 pm
The ones I got off Ebay can do a wide range. Here is a link:
Fri Jan 23, 2015 6:11 pm
Dumb question but how do these hook up to a battery source?
Mon Mar 30, 2015 7:39 pm
postive to postive negative to negative
Mon Mar 30, 2015 7:56 pm
I guess I should have clarified...do they come with cables that hook straight to the battery? Or do I need to buy some adapter? Thanks
Mon Mar 30, 2015 7:59 pm
they come with about 6" of wire coming of both sides . you just need to add the correct connector for you application.
Mon Mar 30, 2015 8:01 pm
Mon Mar 30, 2015 8:05 pm
Anyone have the link to the particular brand they like? I know they are pretty generic it seems but all yalls look good.
Mon Mar 30, 2015 8:08 pm
I get mine from superbrightleds.com
Pay quite a bit more but I like red, and the smaller chipset outshines the cheaper larger chipset, and that's where I get all of mine, I did install the supernight leds from amazon in 3 different friends boats so far but those were green and white, their green is bright as shit, and $15 a 15ft roll.
Mon Mar 30, 2015 8:16 pm
Mon Mar 30, 2015 8:23 pm
Rspade connectors basically, if I tried to explain my wiring diagram of my boat it wouldn't happen, just hook your positive to positive and negative to negative, just like anything else.
Mon Mar 30, 2015 8:36 pm
Tue Mar 31, 2015 4:51 am
Tue Mar 31, 2015 7:57 am
Can you cut them up in different lengths and solder pigtails on them for multiple locations?
Tue Mar 31, 2015 9:30 am
the ones I had, yes. There are designed marks where you had to cut. But you would have to gently cut back some the the plastic to expose the terminals and then solder new wires to it.
Tue Mar 31, 2015 10:29 am
1852 Dfou custom 35gtr
Tue Mar 31, 2015 10:31 am
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Tue Mar 31, 2015 10:34 am
For the guys that are mounting them under the catwalks, are yall centering them under the walk or what?
2015 GatorTrax 1750 /2015 GatorTail GTR35.
Fri Apr 03, 2015 2:31 pm
Wait til dark, play with placement and figure out where you like your light, peel then place. Easiest way to me.
Fri Apr 03, 2015 4:25 pm
Fri Apr 03, 2015 9:53 pm
do y'all run a surge breaker on these?
Sat Apr 18, 2015 10:36 am
Sat Apr 18, 2015 3:22 pm
Sat Apr 18, 2015 3:35 pm
For long term reliablity, best to run waterproof fuse holders to stop corrosion. Especially if running in salt water . I also spray contacts with a little corrosion x before I close water proof lid. They are only about 2-5 bucks a fuse a fuse holder.
Sat Apr 18, 2015 7:56 pm
Pictures of my boat layout. I wired one set backwards for a comparison shot. Supernight rgb leds. 12 different colors plus a dimming option.
1650 ribbed abused by a Gt-35 and push pole reverse
Sun Apr 26, 2015 10:27 pm
Users browsing this forum: No registered users and 127 guests
