It is currently Wed Dec 17, 2025 11:55 pm
Reply to topic  [ 11 posts ]
 25 HP Godevil help needed for first timer
Post 25 HP Godevil help needed for first timer
I have a 25 hp kohler on a 1648 flat bottom, the boat has a scissor blind on it, the motor seems to have great takeoff but that's it, 2 guys and gear on open water was only 14 mph, maybe I'm expecting to much, any advice or tips would be helpful!
Sat Oct 31, 2015 4:07 pm
Post Re: 25 HP Godevil help needed for first timer
Sounds like it runs good. My guess is your prop is worn. Look at the gdevil website at a pic of a. New prop. Does it look like yours?
Tue Nov 03, 2015 11:36 pm
That speed is right on track for that sort of rig. There may be more to be had with a prop change but 2 guys, hunting gear, and a blind is asking a lot from 25hp
-Custom pool noodle
-stage 4 water wings
Wed Nov 04, 2015 6:44 am
For reference my 1752 alweld with 27 hp Kohler mudbuddy lt runs 16.5-17 with 2 people battery and troller . But I have it on a 20 inch transom . I had to redo my transom it was running 14.5 on a 22.5 in transom and once I cut it down it gained 2 mph easy and is easi er to hold in water . I'm like the other guys your in the ballpark in mph but between transom and prop wear you possibly could stretch it for more mph
Wed Nov 04, 2015 7:19 am
It has a brand new 9x7 hill marine prop on a 15" transom, I just ordered a tach, it doesn't seem like it's winding enough rpmsq
Wed Nov 04, 2015 12:43 pm
What about your cav plate or trailing edge . Is it riding deep or is it popping out wot?.... I'm not sure but gd website shows a 25 hp running a 9x6 prop
Wed Nov 04, 2015 2:58 pm
with a new 9x7 and two men with a scissor blind you should be around 3700 rpm. You should also be running around 18 or so if its a hunt load. I had the same setup for years and loved it. How is the boats attitude? Is it running nose down? Hull could have a hook at the transom.
Wed Nov 04, 2015 5:57 pm
Try a 9x6 prop. I had that engine and got 18 mph out of it on a 18x44 godevil boat.
Wed Nov 04, 2015 8:08 pm
I've never had to fight the prop staying under water yet, now with a load equal to 3 guys all I could get was 6.5 mph, something really doesn't seem set right or the motor is weak
Thu Nov 05, 2015 12:48 pm
Thu Nov 05, 2015 4:33 pm
We did a leak down and compression test last night and both intake valves are shot
Sun Nov 08, 2015 10:15 am
