It is currently Tue Jun 24, 2025 8:55 pm
Reply to topic  [ 19 posts ]
 Long Tail Motor Swap
Post Long Tail Motor Swap
Newbie here, and MMT seems to have wealth of info floating around so hopefully someone can answer my question. Can I take a Beavertail frame that had a 31HP vanguard (engine blew) and do a 1 for 1 swap with a Honda GX630 without any major modifications to the frame? The shaft diameters are different so the yoke will have to change and the PTO heights have a .012" difference. Thanks for any help in advance.
Sun Sep 13, 2015 8:04 am
Post Re: Long Tail Moto Swap
Ok so I got the new to me frame home. I didn't realize I was getting the blown engine too but maybe I can sell it as a parts motor. I ordered my new GX630 today and need this monster off the frame. I'm have a hard time getting the u joint off. I'm slowly tapping it off the shaft but it'll take a while. Any thoughts or tips? I'm sure there is a very simple way I just have no idea.
Thu Sep 17, 2015 9:32 am
What's the story on that briggs?
Thu Sep 17, 2015 12:37 pm
Patience and time. It'll come off.
Pm sent
Thu Sep 17, 2015 1:15 pm
Thu Sep 17, 2015 1:26 pm
Hahahaha.
Thu Sep 17, 2015 1:27 pm
Guy I got it from said he hit a log and popped the motor out of the water. A short while later Sparks and oil flew everywhere and this was the result. It looks as though the governor spring was disconnected. Maybe it just spun apart?
Thu Sep 17, 2015 3:30 pm
Only time I've seen that happen, the connecting rod came out the side. Usually a lack of oil thing...
Thu Sep 17, 2015 3:33 pm
Fri Sep 18, 2015 1:49 am
Fri Sep 18, 2015 9:49 am
Yes all the set screws are removed and I filed down the spot welds on the keys. A guy I work with is gonna help me out. We'll use his tractor bucket to slightly lift it and then we are gonna hear the u joint and slowly tap it off.
Fri Sep 18, 2015 12:54 pm
Ok wd40 did the trick just fine. I got the new u joint, prop and motor today and what do you think... Yep bolt patter is off and I need about 1" spacers under the motor to match the previous PTO height.
Mon Sep 21, 2015 4:05 pm
Also where do you guys have your alternator's rectifier mounted? It says not on the engine for vibration reasons but the only place I can come up with is the u joint cage so not sure if that's any better.
Mon Sep 21, 2015 4:07 pm
Post Re: Long Tail Motor Swap
Got it all done. That Honda runs like a dream. It pushed me and two other grown men up river at 12 mph (my boat is a barge and really plows) down stream I was getting 15+
Tue Oct 06, 2015 6:04 pm
Hell yeah man! Like the cowling too
What RPMs are you at WOT?
Tue Oct 06, 2015 7:20 pm
Thanks my neighbor does vinyl for cars had it laying around. I'm at 3600 ish WOT with a 9x5 hill prop
Tue Oct 06, 2015 7:31 pm
Very nice build / swap.
Do you mind to find out who makes the vinyl wrap and name of the pattern?
Thank you in advance!
Wed Oct 28, 2015 7:07 am
Never seen a vinyl wrap, but pretty sure that's Max-4. I've seen guys send their cowling off to get dipped (water imaging) and turn out pretty good. It's kinda pricey though.
Thu Oct 29, 2015 4:36 am
Thanks. It is Max-4. Next time I see him I'll ask about the vinyl. It was just scrap he had lying around.
Thu Nov 12, 2015 8:13 am
Users browsing this forum: Google [Bot] and 53 guests
