It is currently Tue Jun 24, 2025 4:44 am
[ 5 posts ] |
Wetnap
Joined: Mon Jul 18, 2016 8:56 am Posts: 51 Location: Tallahassee, FL
 Banded Axe
Well I haven't had a chance to add any pictures of the new Banded Axe Blind I installed on my 1748 CC ProDrive until now. It was a nightmare to install by myself but I got it accomplished. To mount the blind on this boat I had to fabricate a piece of aluminum to use for the rear mounting brackets since the boat is much wider than the actual blind frame. I took a 58"(?)x6" piece of aluminum and added a 1" 90 for strength. This piece was then fastened to the T-rail blind brackets so I would have a "frame" for the blind frame to set on in the rear. In front I was able to just use the T-rail blind brackets.
I don't have any pictures of the finished product but figured I would show some of the pictures of the process. I have added more raffia grass and trimmed it to be flush with the water line. I also had to remove some of the zip ties from the camo netting so I could get the front and back deck portions to drape so It wouldn't look so square. And while I was at it, I decided to add some lights. All in all, I am very pleased with the finished product.
_________________ 1748 Pro-Drive CC/Stage 1 36hp PD FPR
Thu Oct 13, 2016 5:34 am |
Wetnap
 Re: Banded Axe
more pics
Thu Oct 13, 2016 5:35 am |
geraldrn
Joined: Tue Jan 15, 2013 5:00 pm Posts: 77 Location: Southern Arkansas
 Re: Banded Axe
Looks real GOOD.
_________________ GD 1644-23 GDSD
Thu Oct 13, 2016 8:32 am |
deucem
 Re: Banded Axe
If you haven't already, I would recommend cutting your raffia off just above the water line. I've had it wrapped in my prop shaft and have also found it on my trailer axle inner seal.
_________________ 2010 GTR35 pushing an 1860 Gator-Tail Extreme
Fri Oct 14, 2016 9:50 am |
Wetnap
 Re: Banded Axe
I did that as soon as I put it in the water. I had it hanging way too low.
Fri Oct 14, 2016 10:41 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 147 guests |
