It is currently Sat Jun 21, 2025 11:49 am
Reply to topic  [ 10 posts ]
 gear reduction swomp lite
Post gear reduction swomp lite
Hey guys does any one know if the kohler 7hp with 2/1 gear reduction will bolt up the the swomp lite frame i think this would help my small rig out alot
Fri Mar 17, 2017 7:57 am
Post Re: gear reduction swomp lite
I've got a 9hp Honda 2:1 in a Go Devil frame and it isn't meant for speed. It spins a 10x9 prop but only at 1850rpm 10mph empty and 6mph loaded. Unless you are pushing a barge extremely slow I wouldn't use a gear reduction on a long tail.
Go Devil 1860 35 GDSD
Weldcraft 1548 22hp Predator GDLT
Sun Mar 19, 2017 8:59 am
Sun Mar 19, 2017 12:38 pm
Not a worm gear by like a planetary gear
Sun Mar 19, 2017 12:39 pm
With to people and gear i cant plane on a 1436 do you think it would help get the load up or would more power be better
Mon Mar 20, 2017 3:44 am
I would lean towards that the motor doesn't need gear reduction but the prop pitch and diameter to get the rpms of your motor in the "range". Sometimes less pitch or diameter will help speed and/or load carrying abilities. Back in the day a ran a 16hp GDLT changed from a 14x42 to a 16x44 - got a little more speed and load carrying ability. A loaded 36" will not plane as good as a 44" with the same load nor a 14' vs 16' in most cases. I got 13-15 mph 16x44(standard ribbed 100 ga Lowe) with 2 adults, dog, gear, and 6 dz. decoys.
Mon Mar 20, 2017 10:52 am
I would go 16hp minimum if possible.
Wed Mar 22, 2017 3:42 am
on a non reduced engine the pto comes off of the crank shaft. on a 2/1 reduction engine the pto comes off of the camshaft. They are in different places on the engine face plate. aside from performance issues - no they will not bolt up on the same frame.
on the Great Salt Lake marsh
Sun Mar 26, 2017 8:28 am
Wed Mar 29, 2017 7:23 pm
Thanks guys i guess im gonna suffer threw another year and than step up to a bigger motor and hull
Thu Mar 30, 2017 9:33 am
Users browsing this forum: No registered users and 75 guests
