It is currently Wed Apr 08, 2026 11:55 am
Reply to topic  [ 14 posts ]
 more rpm for briggs 23hp
Post more rpm for briggs 23hp
What all are you guys doing to get the rpms up on the small blocks and how high are you getting?
Mon Apr 17, 2017 8:39 am
Post Re: more rpm for briggs 23hp
Wed Apr 19, 2017 3:18 pm
Wed Apr 19, 2017 3:46 pm
modded. I was just curious how high people were going
Thu Apr 20, 2017 3:49 am
5k plus when the right parts are installed.
Thu Apr 20, 2017 6:12 am
that's about where I wanna be
Thu Apr 20, 2017 10:46 am
Thu Apr 20, 2017 12:51 pm
rev limiter 4700. Can almost turn 5K with a moderate load when rev limiter is unplugged. Motor is modded. I try not to run over 4300, trying not to blow up this motor. Over 400 hrs on modded motor.
Thu Apr 20, 2017 3:36 pm
I like to cruise around the 4600 mark. Heavy load around 42-4300.
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Thu Apr 20, 2017 9:17 pm
Huck,
on my 23 can I get there with stock carb, manley valves, shimmed springs, high rev valve stems, thin head gaskets and timing key? Or do I need a cam some other stuff? and more $$$
1438 Jon / 23hp MBLT
Fri Apr 21, 2017 8:40 am
Keep digging in that wallet...
-Custom pool noodle
-stage 4 water wings
Fri Apr 21, 2017 1:02 pm
Fri Apr 21, 2017 1:12 pm
Rods, pistons, carb, thin head Gaskets, Repair the factory heads from crushing, cam, and adjust timing if needed. It will be a hot rod mamma jama!
Fri Apr 21, 2017 1:18 pm
ive got modded heads, mikuni carb, cam but im not done im going to go back into it and do crank,rods,and pistons end of summer just cant figure out if I want to do 2o or 30 over pistons yet,
Mon Apr 24, 2017 10:44 am
