It is currently Fri Dec 19, 2025 6:31 am
Reply to topic  [ 8 posts ]
 How much power do I need?
Post How much power do I need?
I am having built a 1960 boat that will have pods, the estimated weight is 1300 lbs. Im looking at putting 4 guys and gear. If i bought the prodrive 37 i assume i will need mods? If i need them how much hp do i have to bring it up to thankyou
Sun Jul 30, 2017 4:54 pm
MMT Moderator
Post Re: How much power do I need?
GTB 1860 w/ 2019 GTR40XD-HO
Mon Jul 31, 2017 3:11 pm
I'd plan for one outboard or two mudmotors.
And I'd make it an even 20' in either case.
Mon Jul 31, 2017 3:29 pm
1854 Brother Breaux and Boss 40XP and 90hp outboard.
Fri Aug 04, 2017 8:41 am
You be aight just scratch the pods idea...
I run an 1860 with a unmodded 37 and hunt 3-4 people all the time out of it, occasionally 5. I definitely dont have any speed or plaining out problems out of it either. I dont think a foot longer will make all that much of a difference, I don't imagine it would add anymore that 50-75 pounds.
I have no idea why some people think a boat that size wont work with a singe mud motor...i guess if it wont run 30+ they dont want it. Hell I even think i want a 20x54 when this one kicks the bucket
Fri Aug 04, 2017 5:37 pm
Is the 1300# the hull weight or a combined weight your wanting to move (hull, motor, people) ?
Fri Aug 04, 2017 5:40 pm
The other day with 4 people and fishing poles in my 1848 I run 18 in good water conditions (stock PD 37efi). With a significantly heavier boat and the load you described and stock motor I'd expect you to run 12-15mph max hoping you can get on a plane. If that isn't fast enough for you then you're going to need a different setup.
Pods sometimes work ok with mud motors. But I'd hate for you to spend the money and it screw up the prop from properly making contact with the water and have to chop them off. Why are you wanting pods on that bid of a boat anyways?
2016 Prodrive X 1848 37efi
Sat Aug 05, 2017 6:45 am
Sat Aug 05, 2017 7:45 am
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 1 guest
