It is currently Mon Jul 07, 2025 2:42 pm
[ 5 posts ] |
my lower bearing on my mudbuddy
TinySack
Joined: Mon Aug 03, 2009 4:43 pm Posts: 287 Location: south arkansas
the bearing behind the ole prop leaks grease. i was testing out the new exhaust with the boat trailered and is it ok that a little grease comes out of the bearing or is the bearing shot
_________________ Starting to wonder why my mother always called me special. 1750 GatorTrax HDeck 45 performance v-twin marshmellow double barrel exhaust premium oak reverse w/minnkota cruise control
Tue Mar 30, 2010 11:19 am |
TinySack
 Re: my lower bearing on my mudbuddy
got it figured the play in the bearing in from1/16th to 1/8 inch which that is fine being its a water cooled bearing they tend to heat up and let a little grease out so bearing is good and if the seals are out ill be out only 30 bucks. maybe this will help others out as well
Tue Mar 30, 2010 1:13 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
careful with that tiny. i had a bearing go bad on my old 31 sport. that bad bearing ended up scoring the shaft. i had a local dealer just send the lower to mudbuddy to get rebuilt. seals, bearings, shaft and freight totaled right at $500.
_________________ 1850 & 36pd
Thu Apr 01, 2010 1:38 am |
deadbird8
I posted pics of re-doing the seal/race on the MB forum.
Like Med said- a cheap fix for that rear seal and race (do both of them at the same time) so you don't loose bearings or your shaft.
Fri Apr 02, 2010 8:15 pm |
TinySack
thanks for the help got it fixed
Tue May 04, 2010 11:59 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 24 guests |
