It is currently Sun Sep 21, 2025 12:11 am
Reply to topic  [ 2 posts ]
 2008 27hp prodrive
Post 2008 27hp prodrive
My engine has about 100 hours on it. It cranks no problem. When I give it gas, the engine will rev up. If i put it in gear and give it gas, it will die. It was doing something similar last year and it was a bad fuel pump.
Does this symptom sound like the bad pump again?
Why would it die when in gear and I give it gas?
Thanks
Sat Oct 12, 2019 6:17 pm
Post Re: 2008 27hp prodrive
Something bound up in the drive train causing it to lug too much? If you ease into the gas does it die? Clean your carb. Main jet or needle jet could be clogged.
#GhostBoat
Sat Oct 12, 2019 7:52 pm
