It is currently Mon Feb 02, 2026 4:25 am
Reply to topic  [ 12 posts ]
 Gasket removal question
Post Gasket removal question
What is the most efficient way to remove the factory head gasket form the block?
Thu Feb 04, 2016 10:28 am
Post Re: Gasket removal question
Razor blade scraper works well
Thu Feb 04, 2016 11:28 am
That is what I figured. Didn't know if there was any kind of release agent on the market you guys were using in conjunction with a plastic scraper.
Thu Feb 04, 2016 12:03 pm
After I scrape, I use acetone on a rag to clean any residue.
Thu Feb 04, 2016 12:49 pm
90 die grinder with 3m pad
Thu Feb 04, 2016 1:54 pm
sharp razor for the thick stuff, a scotch brite pad works good for the little shit. Schmitt got it^^
Thu Feb 04, 2016 2:03 pm
:lol: I like to a papertowel in the pushrod galleys to catch the small stuff. Then vacuum out after scraping. Makes for a nice cleanup. Skip on the grinder :lol:
Thu Feb 04, 2016 2:16 pm
I put paper towels in the galleys, razor scraped, scotch brite, and acetoned.
Thu Feb 04, 2016 2:26 pm
I go get the girl that works the local corner, run a lil of dat crotch rot on the case. Let it set, wipe away and your good to go. No need for tools
Thu Feb 04, 2016 4:52 pm
That might work as well.... did not think about the blue waffle ooze.
Thu Feb 04, 2016 6:48 pm
Permatex gasket remover. oven cleaner and a plastic scraper or a plastic credit card edge to scrape with. I have never seen a engine builder yet that used a die grinder and rollex discs. There is a ra finish that needs to be maintained on a aluminum head surface. Also disc dust can migrate in to places it shouldn't be in.
Thu Feb 04, 2016 9:57 pm
Loctite makes a paint striper/gasket remover it works well.
Tue Apr 26, 2016 1:01 pm
