It is currently Fri Nov 20, 2026 10:44 am
Reply to topic  [ 36 posts ]
 Exhaust gaskets problem
Post Exhaust gaskets problem
I keep blowing my exhaust gaskets out on my 35hp vanguard. I have a x-over exhaust on. Does any know what the problem could be?
16x44 Hanko Skiff
35GTR
Tue Mar 20, 2012 9:33 pm
Post Re: Exhaust gaskets problem
Try a thicker gasket.
Tue Mar 20, 2012 9:37 pm
The thickest that ive found around here just blew out the other day. Let me know or give me a link to more heavy duty ones if you know of some
16x44 Hanko Skiff
35GTR
Tue Mar 20, 2012 9:45 pm
Post Re: Re: Exhaust gaskets problem
Tue Mar 20, 2012 9:55 pm
Thanks
16x44 Hanko Skiff
35GTR
Tue Mar 20, 2012 9:56 pm
Flanges maybe warped
Tue Mar 20, 2012 10:00 pm
I use 2 sets of Briggs gaskets
Sent by carrier pigeon.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Mar 20, 2012 10:04 pm
Yeah I just changed them again today and put two, I'll see how that works. My exhaust cracked by the flange and when it was welded it was a tad off and had a little slack between the flange gasket and head..could've been the problem
16x44 Hanko Skiff
35GTR
Tue Mar 20, 2012 10:16 pm
Wed Mar 21, 2012 5:10 am
Thanks I'll see how 2 gaskets work out
16x44 Hanko Skiff
35GTR
Wed Mar 21, 2012 12:38 pm
2801 is the size you want. These work well.
http://www.cbperformance.com/catalog.asp?ProductID=519
Wed Mar 21, 2012 12:54 pm
35 GTR - 1754 Extreme
Wed Mar 21, 2012 1:02 pm
Fuck Tony b. I'm tryna get rich! :lol:
Wed Mar 21, 2012 1:05 pm
Wed Mar 21, 2012 1:21 pm
Thu Mar 22, 2012 5:52 am
18x52 Widow Maker Hull being pushed by a HD 5500 BAMF...
Thu Mar 22, 2012 7:59 am
Just installed brand new second hand EVT on my PD, and I can feel air leaking at the flanges when I crank it up. I doubled up the gasket on one side, because I noticed the gasket still had a little play in it when tight. Well the gasket got tight, but still air leaking through both flanges.
Moral of the story: it looks like I need to order the gaskets mentioned above...
Wed Mar 28, 2012 8:19 pm
Wed Mar 28, 2012 8:29 pm
I think I might try to loosen all the bolts on the exhaust and support bracket, then tighten the exhaust flanges first then support bracket second. Maybe the support bracket needs to give a little in order for the flanges to fit tight. I'll check the straightness of the flanges as well
Wed Mar 28, 2012 8:43 pm
The flanges on my EVT had to b turned a certain way to bolt up the exhaust.
18'x54"CC Hanko/ 36PD
Thu Mar 29, 2012 8:18 am
Thu Mar 29, 2012 9:34 am
The one I have has the slip flanges. I had to adjust them a little for it to bolt on...
Thu Mar 29, 2012 9:45 am
Thu Mar 29, 2012 9:53 am
Yea you couldn't tell in the pic from that angle. Although I talked to BoatDr and he thinks it may just be the air from the fan blowing down near the exhaust flanges. I need to go run it a while to look for anything black coming from the flanges to determine if there's a leak or not.
Thu Mar 29, 2012 9:55 am
Just mix up some real soapy water and spray on while motor is idling. That will tell you right away.
Thu Mar 29, 2012 3:49 pm
Found this old thread. The link above to the 2801 gaskets is no longer working. Anybody know where these gaskets could be found? Thanks!
Mon Jun 29, 2015 9:34 pm
Pm or call Boatdr. He'll probably have exactly what you need, or can tell you where to get them. Cb5331 probably knows too and will likely chime in here. If not him, someone will.
Mon Jun 29, 2015 9:38 pm
It's Volkswagen exhaust gasket, I can't find a link for any of the thick compression style now.
Tue Jun 30, 2015 4:51 am
If you use the compression type with a stock exhaust, make sure to put a washer or some type of spacer between the stock bracket and the engine block. The thicker gaskets push the exhaust down a little further. I didn't add the washer last time and I put strain on the exhaust flanges causing one to crack
17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true."
"Where'd you hear that?"
"The internet"
Tue Jun 30, 2015 5:17 am
http://www.cbperformance.com/ProductDet ... tCode=2801
Here ya go I just got some about a month ago.
Tue Jun 30, 2015 5:23 am
I have had good luck with the Red High Temp RVT. It got me out of a jam once and haven't been back to regular gaskets yet.
1754 XSeries Kawi Powered PRODRIVE ...
Tue Jun 30, 2015 9:48 am
These are the one's we use.
Tue Jun 30, 2015 10:53 am
I've always used stock and never had trouble. Cb why are there 4 per pack, if they collapse, should use one per side. Am I wrong?
Tue Jun 30, 2015 1:35 pm
If I'm not mistaken these are for a VW but fit the briggs as well. The VW has four header pipes
"The internet"
Tue Jun 30, 2015 2:07 pm
Yep...one per side, and a set of spares..
Tue Jun 30, 2015 2:50 pm
Good thread - running double gaskets myself.....
Eat - Sleep - Hunt ! ! !
Tue Jun 30, 2015 3:50 pm
