It is currently Fri Jul 11, 2025 11:25 pm
Reply to topic  [ 108 posts ]  Go to page 1, 2, 3  Next
 leveling kit
Post leveling kit
I am looking to level my 2011 Chevy 2500HD Dmax. I am looking for a kit that will level the front up with the back. What kit do you suggest? Thanks. Netman
18x48 GDSD boat
Sun May 05, 2013 10:53 am
Post Re: leveling kit
I think it's just a torsion key
Sun May 05, 2013 10:56 am
They have one that replaces ur back bracket and pulls the back bed down almost level. I had it done to my f150
1852 Dfou custom 35gtr
Sun May 05, 2013 10:58 am
Crank your keys up just a little bit, and get you a 2.5 to 3" Leveling kit for the front. Being that its a 3/4 ton it will be a little highier in the back and will require a pretty good sized level up front
1850 Uncle J
Delta Performance level 4 GTR
Sun May 05, 2013 11:07 am
http://roughcountry.com/suspension/4wd- ... _9593.html
Gator Trax Hybrid 1654 HuntDeck
Sun May 05, 2013 11:32 am
Sun May 05, 2013 11:34 am
I have always used ready lift leveling kits for my silverado, tahoe, and my f250. never had a complaint. 2.5 inch for a HD truck.
18x54 GTB 35GTR "the hairy merganser II"
"Sometimes you just gotta hang your pistols up and let your hair down"
Sun May 05, 2013 11:46 am
The 2500s still have torsion bars
1754 x series prodrive
36 hp prodrive
Sun May 05, 2013 11:58 am
if you want to do it right do this
http://www.cognitomotorsports.com/produ ... .html#pos8
your stock shocks and upper control arms are limiting factors in how much you can crank your torsion bars with factory or after market "leveling keys"
I gave up mud motors
Sun May 05, 2013 12:00 pm
1646 Gatortail dragging a stage 1 GTR
Sun May 05, 2013 12:21 pm
1850 Uncle J
Sun May 05, 2013 12:32 pm
I got 2.5" keys from rough country and came up a lot but still sat unlevel on my 2500, so cranke keys half way and it sits perfect now and rides like it did stock
Sun May 05, 2013 1:28 pm
Main thing I was wondering is how the aftermarket keys affect ride quality. Has anyone had less than favorable results?
Sun May 05, 2013 1:32 pm
Just like mentioned before. All depends on how much you crank your torsion bars. The more you crank the stiffer your ride is gonna be and the more wear and tear on your front end parts.
36 hp prodrive
Sun May 05, 2013 2:49 pm
Tightening Torsion bars will bring the bottom of the tires in and cause them to wear prematurely.
Sun May 05, 2013 2:55 pm
^this
Sun May 05, 2013 3:05 pm
No shit, that's why I'm asking if the aftermarket keys will lessen that or is it just the same as cranking the stock torsion bars?
Sun May 05, 2013 3:12 pm
Thinking of doing the same for mine. Would an alignment take care of any issues with aftermarket keys?
Sometimes it's best to just keep your fingers quiet...
Sun May 05, 2013 3:18 pm
IFS on a heavy duty truck... :shock:
Sun May 05, 2013 3:37 pm
Yes. Your cranking your bars regardless. After market keys may let you crank a little more than your oem ones. I know the 99-07 classic trucks you could put ford keys and crank more than your oem keys. Idk if it's the same with the 2500s.
36 hp prodrive
Sun May 05, 2013 3:39 pm
Sun May 05, 2013 3:47 pm
some of yall have no clue and just need to shut up :roll:
For gm trucks
Ford keys can be used on OBS and NBS trucks. They are a higher indexed key from a 1997 to 2003 Ford F-150 that swap into the new 4wd trucks. They are for half ton trucks only. They can be found at any local ford dealer by asking for torsion adjusters or the part number is:
(2) XL3Z5B328CA
Here is a picture of a new Ford Torsion Key installed.
Torsion Key Install:
Ford Keys and new Torsion Bars are very easy to install yourself. You can use a 2 arm gear puller, some use a balljoint press, or a special torsion unloading tool that can be rented from a member here:
http://www.gmfullsize.com/forum/showthread.php?t=78832
Leveling Kits:In most cases they are the same thing in a different box. Don't spend money on ebay or from an off-road shop when you can get new keys for $60 from any dealership.
3/4 Ton Trucks:
If you have a 2500 you don't want to use Ford Keys for your truck. They are not indexed correctly. Instead stock 1500 keys will get you more height in the front. "Green" Keys will also allow you to crank up higher. GM Part Number:
#15592573
Adding different keys puts the same stress on the front end as cranking the stock keys. The different key has a different index which puts more load on the bar in the set position. Therefore with a stock key you may tighten the bolt 10 turns. with the aftermarket key it would put the rate of twist on the torsion bar the same as the factory one without the bolt tightened.
Leveling kit vs tightening your keys: each affects the ride the same and will put more wear on your upper ball joints at increased angles.
on 2007 and new trucks the upper control arms limit the droop the stock suspension can take when cranking the bars.
when you do tighten the bars you have to get a alignment after.. it will kick the top of the tires out and make them off camber. you can adjust this at home if needed before going get a alignment by loosining the cam adjusters on the upper control arms.
Sun May 05, 2013 3:50 pm
Sun May 05, 2013 4:11 pm
Sun May 05, 2013 4:16 pm
Sun May 05, 2013 4:34 pm
Drop the back and be done with it!!!!
Sun May 05, 2013 4:48 pm
Sure, I guess I could just lower my truck and put a picture of it in the bad ass thread...
Sun May 05, 2013 5:01 pm
Sun May 05, 2013 5:29 pm
Do not put a leveling kit on!!!! It will ride horrible my 11 dmax rides so ruff now my wife hates to ride with me. Do a 4 or 6" lift. Whatever you do take a ride in one with it before you do it. I promise its that bad
Sun May 05, 2013 5:34 pm
Why level a 3/4 ton truck? Its that way so when you are pulling (what you do with a 3/4 ton), you ride more level.
Sun May 05, 2013 5:38 pm
Sun May 05, 2013 5:42 pm
Call Hurricane Offroad in Lake Charles
Sun May 05, 2013 5:52 pm
Sun May 05, 2013 6:06 pm
Sun May 05, 2013 6:33 pm
Sun May 05, 2013 7:51 pm
I pull this boat and it's 30x10 and close to 10, 000#. My truck has no problem. The half tons hold there own these days for occasional heavy towing. Unless your towing all the time a 3/4 is not needed.
My 2 cents:mrgreen:uploadfromtaptalk1367805207245.jpg
Sun May 05, 2013 8:01 pm
How long u think that ecoboost is gonna last pulling that??
Sun May 05, 2013 8:05 pm
I don't know. I only pull it like 50 miles one way.
Sun May 05, 2013 8:13 pm
I'm thinking about bringing it to Louisiana for duck season and either leaving it in Venice or trailering it back and forth to Venice from Prairieville to tow my mud boat down river. I've done the occasional pulling with my 1/2 ton, but just going from Mobile to Orange Beach is a headache and feels dangerous. I had a 3/4 ton before my current truck, and it was night and day difference. The boat weighs around 9,000 #'s, I believe, and is simply too much for a 1/2 ton to carry a long distance.
Sun May 05, 2013 8:16 pm
I can agree with that. It seems you do a lil more towing than the average guy.
Sun May 05, 2013 8:18 pm
Users browsing this forum: Google [Bot] and 107 guests
