It is currently Thu Oct 08, 2026 11:52 am
Reply to topic  [ 93 posts ]  Go to page 1, 2, 3  Next
 Calens cam vs. bps cam
Post Calens cam vs. bps cam
Anybody running calens cam? Is there any thing to worry about it since they are welded up vs the bps cam? Bps cam are back ordered and can't find them anywhere.
Thanks.
Wed Jul 31, 2013 11:09 pm
Post Re: Calens cam vs. bps cam
It's a good cam. I've used it in builds with no issues to date.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Jul 31, 2013 11:14 pm
Is Calen still in the business of selling performance parts? I thought you had to be special to buy stuff from him these days...or at least since earlier this year when all that mess went down on here when a cam was installed wrong causing failure and the installer pointed his finger the wrong direction... :?
Thu Aug 01, 2013 1:43 am
Nothing wrong with a welded cam when done right. In many cases they are better and stronger on the lobe.
Thu Aug 01, 2013 4:00 am
Calen uses gatortail cams duh.
Thu Aug 01, 2013 6:05 am
Thu Aug 01, 2013 6:20 am
Thu Aug 01, 2013 9:00 am
Thu Aug 01, 2013 9:26 am
I talked to him about a cam the other day and he told me he has a cam thats similar to the BPS cam and has had no issues with it what so ever
Thu Aug 01, 2013 9:30 am
Correct
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Aug 01, 2013 9:56 am
It's a hit or miss with cams all a lil different. I wonder if you could just make intake and exhaust valve longer and do same concept
Thu Aug 01, 2013 9:58 am
ive been running Calen's cam for two years since he put my stage one on my motor an never had a issue with any of the work he has done to my motor
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Thu Aug 01, 2013 10:00 am
Thu Aug 01, 2013 10:03 am
Thu Aug 01, 2013 10:08 am
Thu Aug 01, 2013 10:12 am
Thu Aug 01, 2013 10:14 am
Because you will only have 1 thread holding your jam nut on the rocker adjustment.
Thu Aug 01, 2013 10:16 am
How are you measuring your valve? Complete valve are what?
Thu Aug 01, 2013 10:17 am
Thu Aug 01, 2013 10:19 am
And the valve closes????
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Aug 01, 2013 10:22 am
Its a total measurement of deck height, cam lift, valve seat cut, and rocker adjustment.
Thu Aug 01, 2013 10:25 am
The over all of valve whole length
Thu Aug 01, 2013 10:27 am
At the measurement you gave of 3.585 you are fine for the valve to close.
Thu Aug 01, 2013 10:30 am
Thu Aug 01, 2013 10:32 am
10-4
Thu Aug 01, 2013 10:34 am
Also if your geometry isn't correct you can put excess side load on the valve stem causing premature wear on the valve and valve guides.
Thu Aug 01, 2013 11:49 am
Thu Aug 01, 2013 11:50 am
A little of subject but kind of related...Has anyone figured out how to advance timing without a key? Like moving the coils instead?
Thu Aug 01, 2013 12:01 pm
I did, I put the coils on the flywheel and the magnet on the block!
Thu Aug 01, 2013 12:05 pm
OKayy, I was wondering about the balance of the flywheel to the crank. So you put the coils in jest the right spot to keep it balanced right? :lol:
Thu Aug 01, 2013 12:07 pm
Hay Clark ask Uncle Eddie :lol: :lol: :lol:
http://www.youtube.com/watch?v=i6G68ppe ... r_embedded
- Mark Twain
Thu Aug 01, 2013 12:10 pm
Thu Aug 01, 2013 12:13 pm
Thu Aug 01, 2013 12:28 pm
Thu Aug 01, 2013 12:29 pm
Thu Aug 01, 2013 12:34 pm
You'd think it would be a good idea to figure this kinda stuff out BEFORE you start doing work for other people...
Thu Aug 01, 2013 1:00 pm
Thu Aug 01, 2013 2:27 pm
Thu Aug 01, 2013 2:43 pm
:lol: I love this site!
Modded 36 PD draggin' around an 1848 PD boat backwards!
Thu Aug 01, 2013 2:57 pm
