WestEndAngler
MMT Moderator
 Removable Transducer Mounts?
How is everyone mounting their transducers? I want mine removable.
I see some putting them on a spud pole / small pole they can remove or lower/raise as needed with a pin etc. I've seen some hard mounted but in the mud that's just going to get ripped off. I am curious to see how some of y'all are mounting your depth sounders. In my case I have to mount two one on either side of the motor. I know The Shafer has one I saw at Caddo earlier this year. Anyone else?
| Fri Dec 13, 2013 4:18 pm |
missile
Joined: Mon Jun 18, 2012 7:33 pm Posts: 681 Location: DeKalb, Texas between the rivers
 Re: Removable Transducer Mounts?
Used my rear spud pole holder works great. Rais it up and down or remove it all together
_________________ Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's Boat Name: The Gar Barge Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
| Fri Dec 13, 2013 4:22 pm |
WestEndAngler
MMT Moderator
| Fri Dec 13, 2013 4:51 pm |
BayouStateHunter
Joined: Sat May 16, 2009 1:04 pm Posts: 2037 Location: On da Northshore -- Louisiana
Cabelas. And don't you have the same GT 1860 hull as me?
_________________ 1860 GTB/35GTR CC w/ Hoyt Stage 1 - bowfishin'/rodnreel/duckhunting
| Fri Dec 13, 2013 4:59 pm |
BayouBuster
Joined: Sat Jun 25, 2011 8:33 am Posts: 1352 Location: Genoa AR
I made a bracket that mounted the transducer to the trolling motor head and just mount the unit itself on the front deck.
Sent from my iPhone using
| Fri Dec 13, 2013 5:16 pm |
calphil
Joined: Sun Feb 26, 2012 10:49 pm Posts: 1715 Location: Kingwood,TX
I believe he has hunt deck
_________________ 1744 WC Custom 25 GTR
| Fri Dec 13, 2013 5:36 pm |
WestEndAngler
MMT Moderator
Yes, I have a hunt deck.
| Fri Dec 13, 2013 5:49 pm |
rob_E
Joined: Wed Jan 25, 2012 12:03 pm Posts: 1763 Location: Prairieville, LA
Get an alumadcer
_________________ 18X54 CC & 35 GTR w/ Hoyts Stage 1
| Fri Dec 13, 2013 6:05 pm |
missile
Yes I just drilled a hole and put a pin in it then when I pull it up the pin goes back through the transducer pipe. Only got to try it once and it read pretty good up to about 20mph nut I also keep it just a little higher than on a normal boat.
| Fri Dec 13, 2013 6:15 pm |
missile
On my dual rig I welded a 1.25 pipe to a piece of plate and bolted it to the top of my hunt deck and rigged it the same way.
| Fri Dec 13, 2013 6:16 pm |
missile
I forgot I did go back and drill a second hole through the pipe transducer is mounted on but only one hole through the spud pipe.
| Fri Dec 13, 2013 6:25 pm |
50fps
I use a 1x2 and a c-clamp.
| Fri Dec 13, 2013 7:35 pm |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
I got a threw hull on two of my rigs. They are fiberglass tho. Don't know if they will shoot threw aluminum. They probably would. Edit- just checked they won't
_________________ 23 swomp/ 1542 tracker
| Fri Dec 13, 2013 8:15 pm |
rob_E
| Fri Dec 13, 2013 8:21 pm |
ARguide
Joined: Tue Jul 09, 2013 10:42 pm Posts: 372 Location: AR
Bought a trolling motor with the transducer in the foot. We will see how it works.
| Fri Dec 13, 2013 9:45 pm |
cajun1085
Joined: Fri May 10, 2013 2:57 pm Posts: 183 Location: Silver Spring, MD
Ram Kayak mount works well for me and looks clean.
_________________ GTB 1646 w/HD, Boat Blind-25GTR
SOUTHEAST GATORTAIL
| Sat Dec 14, 2013 2:12 am |
missile
Cajun will it stay where you put it when running or does it move. I like that looks like you would have some give if you hit something
| Sat Dec 14, 2013 5:59 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
| Sat Dec 14, 2013 7:45 am |
CAJUN OUTLAW
If u only gonna use it with the troller, why not mount it to the troller?
| Sat Dec 14, 2013 3:16 pm |
VooDoo Daddy
_________________ VooDoo--what you get when you leave your Voo outside all night long.
| Sat Dec 14, 2013 5:40 pm |
rob_E
$185 ish
| Sat Dec 14, 2013 7:43 pm |
cajun1085
SOUTHEAST GATORTAIL
| Sat Dec 14, 2013 9:35 pm |
WestEndAngler
MMT Moderator
| Tue Dec 17, 2013 2:12 pm |
The Shafer
Joined: Tue Jan 13, 2009 7:46 pm Posts: 1947 Location: Longview. TX
_________________ WC 1848 Bateau w/ 36 PD FPR
| Wed Dec 18, 2013 3:38 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
| Wed Dec 18, 2013 4:08 pm |
Full Throttle
Joined: Sun Jan 25, 2009 8:09 pm Posts: 1268 Location: North Texas
_________________ WC Custom 1854
| Wed Dec 18, 2013 7:30 pm |
txkingfisher
Joined: Fri Apr 26, 2013 1:09 am Posts: 1121 Location: SETX
Epoxy that motherfucker to the bottom of the boat on the *INSIDE* and you will never have to fuck with it again. I learned this trick working on jet drive gillnet boats in bristol bay alaska. They jump sandbars and drag ass across flats for miles out there. The transducer will read right through the hull with no problems. Works on aluminum, fiberglass, and steel hulls.
_________________ 13' Jefferson fiberglass skiff - 14 Copperhead
| Wed Dec 18, 2013 8:30 pm |
4Cody4
Are you talking about the alumaducer or whatever, or just a standard transducer?
| Wed Dec 18, 2013 8:46 pm |
txkingfisher
standard transducer. just make sure the part that sends and receives the sound waves is completely coated with the epoxy.
| Wed Dec 18, 2013 8:54 pm |
cajun1085
SOUTHEAST GATORTAIL
| Thu Dec 19, 2013 2:36 am |
cajun1085
SOUTHEAST GATORTAIL
| Thu Dec 19, 2013 2:37 am |
robin2
Joined: Mon Apr 13, 2009 6:38 pm Posts: 400 Location: Pecanierre,La
This if ya need structure/ side scan.
| Fri Dec 20, 2013 12:34 pm |
WestEndAngler
MMT Moderator
Thanks fellas I went with kayak ram mount for both transducer and structure scan. I have a hunt deck so the trolling motor bracket wouldn't work. I have everything mounted just need to take pics.
| Mon Dec 30, 2013 8:56 pm |
JLACOUR
Joined: Wed Jan 14, 2009 8:18 pm Posts: 4915 Location: Lake Jackson, TX
I see WEA did his already but I bought the same one as post #4 and modified it.
_________________ 37 PD EFI FPR 18x48 Tiller SOLD -- 36 PD EFI FPR 18x48 Stick Steer SOLD -- 27 PD FPR 16x36 Skiff
| Sat Feb 08, 2014 6:05 pm |
BayouStateHunter
Your welcome.
| Sat Feb 08, 2014 7:51 pm |
JLACOUR
I would say thanks but didn't notice yours till I posted mine. Thanks anyway  Sent from my iPhone using Tapatalk
| Sat Feb 08, 2014 8:00 pm |
JLACOUR
Down position
| Sat Feb 08, 2014 9:18 pm |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
Fuck an Alumiducer. Bought one, never could get it to work, returned it and got the Cabelas bracket.
| Sun Feb 09, 2014 3:13 am |
