It is currently Thu Jun 04, 2026 10:56 am
Reply to topic  [ 38 posts ]
 Removable Transducer Mounts?
MMT Moderator
Post Removable Transducer Mounts?
How is everyone mounting their transducers? I want mine removable.
I see some putting them on a spud pole / small pole they can remove or lower/raise as needed with a pin etc. I've seen some hard mounted but in the mud that's just going to get ripped off. I am curious to see how some of y'all are mounting your depth sounders. In my case I have to mount two one on either side of the motor. I know The Shafer has one I saw at Caddo earlier this year. Anyone else?
GTB 1860 w/ 2019 GTR40XD-HO
Fri Dec 13, 2013 4:18 pm
Post Re: Removable Transducer Mounts?
Used my rear spud pole holder works great. Rais it up and down or remove it all together
Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's
Boat Name: The Gar Barge
Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Fri Dec 13, 2013 4:22 pm
MMT Moderator
Fri Dec 13, 2013 4:51 pm
Cabelas. And don't you have the same GT 1860 hull as me?
Fri Dec 13, 2013 4:59 pm
I made a bracket that mounted the transducer to the trolling motor head and just mount the unit itself on the front deck.
Sent from my iPhone using
Fri Dec 13, 2013 5:16 pm
I believe he has hunt deck
1744 WC Custom
25 GTR
Fri Dec 13, 2013 5:36 pm
MMT Moderator
Yes, I have a hunt deck.
Fri Dec 13, 2013 5:49 pm
Get an alumadcer
Fri Dec 13, 2013 6:05 pm
Yes I just drilled a hole and put a pin in it then when I pull it up the pin goes back through the transducer pipe. Only got to try it once and it read pretty good up to about 20mph nut I also keep it just a little higher than on a normal boat.
Fri Dec 13, 2013 6:15 pm
On my dual rig I welded a 1.25 pipe to a piece of plate and bolted it to the top of my hunt deck and rigged it the same way.
Fri Dec 13, 2013 6:16 pm
I forgot I did go back and drill a second hole through the pipe transducer is mounted on but only one hole through the spud pipe.
Fri Dec 13, 2013 6:25 pm
I use a 1x2 and a c-clamp.
Fri Dec 13, 2013 7:35 pm
I got a threw hull on two of my rigs. They are fiberglass tho. Don't know if they will shoot threw aluminum. They probably would. Edit- just checked they won't
23 swomp/ 1542 tracker
Fri Dec 13, 2013 8:15 pm
Fri Dec 13, 2013 8:21 pm
Bought a trolling motor with the transducer in the foot. We will see how it works.
Fri Dec 13, 2013 9:45 pm
Ram Kayak mount works well for me and looks clean.
GTB 1646 w/HD, Boat Blind-25GTR
SOUTHEAST GATORTAIL
Sat Dec 14, 2013 2:12 am
Cajun will it stay where you put it when running or does it move. I like that looks like you would have some give if you hit something
Sat Dec 14, 2013 5:59 am
http://www.radarsonics.com/Spec%20Data% ... aDucer.pdf
Sat Dec 14, 2013 7:45 am
If u only gonna use it with the troller, why not mount it to the troller?
Sat Dec 14, 2013 3:16 pm
VooDoo--what you get when you leave your Voo outside all night long.
Sat Dec 14, 2013 5:40 pm
$185 ish
Sat Dec 14, 2013 7:43 pm
SOUTHEAST GATORTAIL
Sat Dec 14, 2013 9:35 pm
MMT Moderator
Tue Dec 17, 2013 2:12 pm
WC 1848 Bateau w/ 36 PD FPR
Wed Dec 18, 2013 3:38 pm
Wed Dec 18, 2013 4:08 pm
WC Custom 1854
Wed Dec 18, 2013 7:30 pm
Epoxy that motherfucker to the bottom of the boat on the *INSIDE* and you will never have to fuck with it again. I learned this trick working on jet drive gillnet boats in bristol bay alaska. They jump sandbars and drag ass across flats for miles out there. The transducer will read right through the hull with no problems. Works on aluminum, fiberglass, and steel hulls.
Wed Dec 18, 2013 8:30 pm
Are you talking about the alumaducer or whatever, or just a standard transducer?
Wed Dec 18, 2013 8:46 pm
standard transducer.
just make sure the part that sends and receives the sound waves is completely coated with the epoxy.
Wed Dec 18, 2013 8:54 pm
SOUTHEAST GATORTAIL
Thu Dec 19, 2013 2:36 am
SOUTHEAST GATORTAIL
Thu Dec 19, 2013 2:37 am
This if ya need structure/ side scan.
Fri Dec 20, 2013 12:34 pm
MMT Moderator
Thanks fellas I went with kayak ram mount for both transducer and structure scan. I have a hunt deck so the trolling motor bracket wouldn't work. I have everything mounted just need to take pics.
Mon Dec 30, 2013 8:56 pm
I see WEA did his already but I bought the same one as post #4 and modified it.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Sat Feb 08, 2014 6:05 pm
Your welcome.
Sat Feb 08, 2014 7:51 pm
I would say thanks but didn't notice yours till I posted mine. Thanks anyway :-)
Sat Feb 08, 2014 8:00 pm
Down position
Sat Feb 08, 2014 9:18 pm
Fuck an Alumiducer. Bought one, never could get it to work, returned it and got the Cabelas bracket.
Sun Feb 09, 2014 3:13 am
