It is currently Mon Jun 30, 2025 2:14 pm
Reply to topic  [ 56 posts ]  Go to page 1, 2  Next
 Headwork
Post Headwork
Does anyone know of anyone who does head work near laurel, ms? Looking to do a little tuning to her before season creeps in...
1854 GatorTrax GE chased by MB 5500 Mag
Fri Jul 25, 2014 5:20 pm
Post Re: Headwork
Send them to Jamie b along with your intake. Thank me later.
HOTSAUCE170 wrote:
Fri Jul 25, 2014 5:27 pm
Post Re: Headwork
Catch him soon before the doors close for hunting season!
Fri Jul 25, 2014 5:36 pm
Post Re: Headwork
Fri Jul 25, 2014 6:36 pm
Post Re: Headwork
Sending them to LA prop to put his magic touch on them then gettin mikuni from Andy in a month.... Hoping to see a load carying improvement
Fri Aug 01, 2014 11:49 am
Post Re: Headwork
Fri Aug 01, 2014 7:24 pm
Post Re: Headwork
Fri Aug 01, 2014 7:25 pm
Post Re: Headwork
I know someone on here has got just headwork and exhaust done... Eventually I want to add mikuni but what speeds, load should I expect to see out of it without the carb? I was getting 26 consistent bump 27 with light load and 2 person load on a 1746 gtb...
Mon Aug 11, 2014 10:01 am
Post Re: Headwork
28 bumping 29 and more bottom end. Don't expect a lot of speed gain, you're not doing anything to compliment the head work. I.E. Carb/cam
Mon Aug 11, 2014 10:19 am
Post Re: Headwork
i had heads cam exhaust on a 1746..gained alot of speed after adding the carb..its high as giraffe puss but you should see good gains from it
Mon Aug 11, 2014 10:51 am
Post Re: Headwork
couldnt run a stock carb ever again after getting the mikuni. Honestly, id rather get a carb first before headwork. You just cant run these motors correctly with the governor linkage systems. Honestly dont know why MM manufactures even let a motor out of the shop with the crap briggs carbs. Add the carb into the costs of a new motor.... That carb is meant to be ran at a constant 3600 rpms. Not between 800-4300
Mon Aug 11, 2014 10:54 am
Post Re: Headwork
17x54 Extreme W/ GTR-35L Stage 1
Mon Aug 11, 2014 11:18 am
Post Re: Headwork
I never had starting or idling issues either on mine and it STILL is night and day with throttle response
Mon Aug 11, 2014 11:30 am
Post Re: Headwork
1748 Cottonmouth Hybrid Custom with a 2015 35GTR
7 yr old Boykin Spaniel
One Badazz wife that that hunts like a champ
ROLL TIDE!!
Mon Aug 11, 2014 11:32 am
Post Re: Headwork
Mon Aug 11, 2014 11:58 am
Post Re: Headwork
Mon Aug 11, 2014 11:59 am
Post Re: Headwork
I figured 28-29ish until the carb was added, just have to wait a minute for the carb... Just got married and that chit ain't cheap ha...
Mon Aug 11, 2014 12:35 pm
Post Re: Headwork
Mon Aug 11, 2014 3:05 pm
Post Re: Headwork
To haul big ass!!
Mon Aug 11, 2014 4:59 pm
Post Re: Headwork
Any break in issues or things to keep in mind once I put my heads back on motor? Also, any cheap tricks or adjustments to get a little more hp besides the carb/cam? Will I create any issues with this headwork done and not changing coils or rev limiter for any reason? I've caught the mod my motor itch and can't stop it....
Mon Aug 11, 2014 5:15 pm
Post Re: Headwork
Wed Aug 13, 2014 4:58 am
Post Re: Headwork
Yes I do, I have bps q exhaust... I have a mud buddy hd 3500 on a gtr boat... Don't chastise me, that's how it was when I bought it on a good deal so I said what the heck...
Wed Aug 13, 2014 5:26 am
Post Re: Headwork
Wed Aug 13, 2014 5:39 am
Post Re: Headwork
How will I know if I have 4350 coils or 4700? From what I've seen, they switched midstream in 2012, which is when my motor was manufactured but classified as 2013 when sold...
Wed Aug 13, 2014 5:01 pm
Post Re: Headwork
Rev outta water and see what it hits. 4350 or 4700. That's what coils you got.
Wed Aug 13, 2014 5:08 pm
Post Re: Headwork
Too simple... Make it sound more extensive next time, thsnks
Wed Aug 13, 2014 5:17 pm
Post Re: Headwork
Thu Aug 14, 2014 6:08 am
Post Re: Headwork
Post Re: Headwork
Marsh jb, what are your specs on your setup and speeds? if you are running heads and exhaust with stock carb, I'd like a comparison with the same mods unless you have other work done...
Thu Aug 14, 2014 5:57 pm
Post Re: Headwork
.040 heads, hoyt mild cam, mm baffled. My boat runs 30-31 all day long. Four people runs 26-28 depending on how fat everyone is.
Thu Aug 14, 2014 6:01 pm
Post Re: Headwork
Dang... That'd be nice, what are your boat dimensions?
Thu Aug 14, 2014 6:37 pm
Post Re: Headwork
17x54 extreme gt boat
Thu Aug 14, 2014 6:43 pm
Post Re: Headwork
So I just got her all back together, and back off the water to give the review of the headwork done... All I can say is that it took some time to get it all pieced back together, short of a valve gasket, it's back together, going to get that tomorrow. Awesome work LA prop, you da man ha. By myself 2 batteries tank of gas trolling motor and yeti rolled 30 consistent, me and a buddy stayed 29 the whole time, unfortunately tach went out but putting new one on tomorrow as well. But the get up and go is a drastic change as well. thank you and if anyone needs headwork LA prop is the guy... Great guy to deal with... Noticed my crank case gasket might have a small leak but going to tighten bolts up and hopefully it will hold up for a little while longer.
Sat Aug 16, 2014 1:17 am
Post Re: Headwork
Post Re: Headwork
I am adjusting the idle rpm to sit around 1100 I think is a sweet spot, but while adjusting the idle screw in the front I realized it was all the way backed out and not coming down any more. My rpm at that time was around 1800 on idle. I then adjusted the screw with spring on the backside of the carb to allow the springs to retract more for the front idle screw in the front of the motor. I am unsure if this is the proper way to make your idle arm hit the front screw because it was sticking, just making sure that's what that back screw with the spring is for on the back of the carb. It's all got tons of slack in it. can't wait to throw it away for the mikuni
Sat Aug 16, 2014 5:12 pm
Post Re: Headwork
Idle at 1100 good lawd u must have some really fat chicks riding with u to slow it down while putting it back on the trailer
Sent from my iPhone using
Sat Aug 16, 2014 5:43 pm
Post Re: Headwork
Sat Aug 16, 2014 5:48 pm
Post Re: Headwork
Ha what is your suggestion aka?
Sat Aug 16, 2014 6:33 pm
Post Re: Headwork
Mikuni. :lol:
Sat Aug 16, 2014 6:48 pm
Post Re: Headwork
Sonerhing is hanging up or sticking. Is your spring allowing the arm to return all the way to idle?
Sat Aug 16, 2014 9:05 pm
Users browsing this forum: No registered users and 166 guests
