It is currently Thu Mar 26, 2026 7:14 am
Reply to topic  [ 29 posts ]
 Depth finder transducer mounting
Post Depth finder transducer mounting
Need some ideas for mounting a transducer on the back of my 1752 with a hint deck. Has anyone made a removable mount of any sort? I run mud and timber all the time and don't want that thing to get ripped off or destroyed. I would like to have the depth finder for when I fish. I'm out of ideas. Thanks in advance.
Sun Dec 28, 2014 8:23 pm
Post Re: Depth finder transducer mounting
They make ones that mount to the floor of the boat that penetrate through the hull so there is no transducer on the outside. It's called a alumaducer
Sun Dec 28, 2014 8:54 pm
Or check with WestendAngler. He has his on a removable ram mount.
Sun Dec 28, 2014 8:55 pm
I modified the bracket from bass pro.
That is in the down position.
I stole the idea from someone else on here.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Sun Dec 28, 2014 9:01 pm
Gator Trax makes one that slides also.
Sun Dec 28, 2014 10:28 pm
That sliding mount is a damn good idea. Thanks for the info guys.
Mon Dec 29, 2014 9:00 am
This is the gator trax style. I ordered the material yesterday to make it, cost under $20 and just going to give my welder a 6 pack for his work.
1754 hybrid huntdeck 35gtr
Tue Dec 30, 2014 9:58 am
Here is the ram mount
Tue Dec 30, 2014 10:25 am
Tue Dec 30, 2014 10:29 am
It moves a little bit, but I haven't had any problems with it.
Tue Dec 30, 2014 12:46 pm
I have the one from Gatortrax. Had a local welder put it on. Works great.image.jpg
Thu Jan 01, 2015 1:23 pm
Glad this thread started. I just got a new GPS/depth finder for Christmas and will be doing this same thing. I would like one that is removable because I only fish with it on odd occasions
Thu Jan 01, 2015 4:42 pm
I'm a fan of the alumaducer for the simple reason that Id forget to pick up one of those sliding mounts and drag it off for sure lol.
-Custom pool noodle
-stage 4 water wings
Thu Jan 01, 2015 5:14 pm
Thu Jan 01, 2015 5:42 pm
Thu Jan 01, 2015 6:20 pm
We ran one on an Alumacraft bass boat. It's mounted at the back of the boat close to the transom. Boat is .100ga
-Custom pool noodle
Thu Jan 01, 2015 10:09 pm
Way I found my spot put 2" water in boat then transducer in bag fill water zip tye then weight it down move to best spot done 3 boats with stock transducer
Mac
driving a gd in ur lake
and i aprove this message
Fri Jan 02, 2015 9:45 pm
What does the water do?
Fri Jan 02, 2015 10:57 pm
I did the water in the boat installing mine also. I think the water mimics the epoxy you use to put it down. When you buy one it comes with instructions. And that's how they recommend you find the sweet spot before mounting it permanently.
Sat Jan 03, 2015 7:51 am
Here is one pokey79 made for me. ImageUploadedByTapatalk1420560045.795312.jpg
No welding required.
pd36 fpr 1754 cc rig
Tue Jan 06, 2015 10:01 am
ImageUploadedByTapatalk1420560161.260397.jpgImageUploadedByTapatalk1420560169.110270.jpg
Tue Jan 06, 2015 10:02 am
Mine isn't a hunt deck, that's just showing it next to his boat. When I get it out the mail and mount it I'll add some pics of it.
Tue Jan 06, 2015 10:04 am
Not to hijack here, but do yall connect your GPS straight to the battery or to a switch panel?
Tue Jan 06, 2015 4:17 pm
Straight with an in line fuse
Tue Jan 06, 2015 4:20 pm
Tue Jan 06, 2015 5:13 pm
I put mine through the switch panel and I am already thinking about changing it.
Tue Jan 06, 2015 5:17 pm
I power mine with a 12v plug into one of my 12v outlets, which are powered from the switch panel.
Tue Jan 06, 2015 8:37 pm
Thanks for all the help guys. I made one out of aluminum that slides up when I'm running the marsh and it slides down and pins when I'm fishing. Works perfect. Gave me a excuse to mess with the new spool gun too.
Fri Jan 16, 2015 4:07 pm
http://www.fishfindermounts.com/#!produ ... ks-&-boats
Sun Dec 20, 2015 9:25 pm
