It is currently Thu Jul 03, 2025 8:32 pm
Reply to topic  [ 4 posts ]
 troller and Humminbird on same battery
Post troller and Humminbird on same battery
welded troller block to the bow of my boat. I wanted to have a 2nd power source to pick up decoys in deeper water and fish. I purchased a humminbird down schan imager to mount to the troller. Have any of you ran your sonar and trolling motor off the same 12V battery? The toller is only a 40lb thrust so its not drawing a lot of amps. Also how did you attach your sonar to the 12v terminals? the sonar has small diameter wires and I do not think crimps will work too well.
Thu Mar 16, 2017 11:08 am
Post Re: troller and Humminbird on same battery
I just installed a Helix 7 and the manual said to run it of the battery for your big motor and not the trolling motor battery.
Thu Mar 16, 2017 11:11 am
I run my TM off the same battery as my depth finder. Wanna be a able to get home. If the tm battery dies it's time to go
Sent from my SAMSUNG-SM-T377A using Tapatalk
Thu Mar 16, 2017 1:12 pm
Run your sonar off cranking battery. The trolling motor will interfere with the sonar if it is on the same battery. I think my cranking battery is a group 24 and runs my helix 5 all day no problem. That's sometimes with my stereo going too. My 2 trolling batteries are group 29.
Every day I'm paddlin'
Thu Mar 16, 2017 3:31 pm
Users browsing this forum: No registered users and 37 guests
