It is currently Mon Jul 07, 2025 3:28 pm
Reply to topic  [ 13 posts ]
 Hopkins on a mud buddy
Post Hopkins on a mud buddy
Order a hopkins 12x12 prop and was told I would have to do a little filing. To me it seems I've done more than a little filing and it still seems to not wanna go on. Just wondering if anyone else has tried this prop on there mud buddy.
Fri May 16, 2014 5:12 pm
Post Re: Hopkins on a mud buddy
Yesir, had the same issue when I owned a MB. I had a few high spots and eventually it went on. Make sure you wipe the shavings off from the shaft.
Fri May 16, 2014 5:39 pm
Fri May 16, 2014 5:43 pm
18/60 Prodive With Dual 37 EFI Prodrives Gen III...
Fri May 16, 2014 5:44 pm
We'll I been using a flat file and I've made a lot more than 2 or 3 passes that's why I was wanting a little input before I kept filing away.
Fri May 16, 2014 5:47 pm
I worked on the prop hex using a 3/4 Allen wrench coated with 80 Grit lapping compound. I used a dead blow lead headed hammer to drive the allen wrench thru the prop hub back and forth until it loosened up. Then repeated the process until the allen wrench was a slip fit thru the hub. Took several passes and a bit of time but felt better about working prop rather than grinding on shaft. Don't know how accurate shaft flats would be if grinder was used. Might take to much off one of the flats and cause an embalance or wobble in prop.
Fri May 16, 2014 7:22 pm
Fri May 16, 2014 7:37 pm
Finally got it on with a little filing on the prop. Thanks for all the help!
Sat May 17, 2014 7:47 am
How does it run?
17x54 Extreme W/ GTR-35L Stage 1
Fri May 23, 2014 2:31 pm
It ran about the same as the big blade so I sent it back to get another inch of pitch put in it.
Tue May 27, 2014 6:50 am
And then?
Tue May 27, 2014 7:14 am
Haven't got it back yet. Hopefully it will be here this week.
Tue May 27, 2014 12:47 pm
Got prop back and ran this weekend. Was about .5 slower than big blade and had a lot of vibration and tiller torque.
Sun Jun 08, 2014 3:55 pm
Users browsing this forum: No registered users and 29 guests
