pnut
 Hopkins on a mud buddy
Order a hopkins 12x12 prop and was told I would have to do a little filing. To me it seems I've done more than a little filing and it still seems to not wanna go on. Just wondering if anyone else has tried this prop on there mud buddy.
Fri May 16, 2014 5:12 pm |
DC
Joined: Wed Jan 21, 2009 9:50 pm Posts: 124 Location: Lakeville, MN
 Re: Hopkins on a mud buddy
Yesir, had the same issue when I owned a MB. I had a few high spots and eventually it went on. Make sure you wipe the shavings off from the shaft.
Fri May 16, 2014 5:39 pm |
pnut
Fri May 16, 2014 5:43 pm |
lil Cajun
_________________ 18/60 Prodive With Dual 37 EFI Prodrives Gen III...
Fri May 16, 2014 5:44 pm |
pnut
We'll I been using a flat file and I've made a lot more than 2 or 3 passes that's why I was wanting a little input before I kept filing away.
Fri May 16, 2014 5:47 pm |
DENNYEDWARDS
Joined: Sun Aug 09, 2009 12:50 pm Posts: 574 Location: Muscatine, Iowa
I worked on the prop hex using a 3/4 Allen wrench coated with 80 Grit lapping compound. I used a dead blow lead headed hammer to drive the allen wrench thru the prop hub back and forth until it loosened up. Then repeated the process until the allen wrench was a slip fit thru the hub. Took several passes and a bit of time but felt better about working prop rather than grinding on shaft. Don't know how accurate shaft flats would be if grinder was used. Might take to much off one of the flats and cause an embalance or wobble in prop.
Fri May 16, 2014 7:22 pm |
DC
Fri May 16, 2014 7:37 pm |
pnut
Finally got it on with a little filing on the prop. Thanks for all the help!
Sat May 17, 2014 7:47 am |
MarshJB
How does it run?
_________________ 17x54 Extreme W/ GTR-35L Stage 1
Fri May 23, 2014 2:31 pm |
pnut
It ran about the same as the big blade so I sent it back to get another inch of pitch put in it.
Tue May 27, 2014 6:50 am |
MarshJB
And then?
Tue May 27, 2014 7:14 am |
pnut
Haven't got it back yet. Hopefully it will be here this week.
Tue May 27, 2014 12:47 pm |
pnut
Got prop back and ran this weekend. Was about .5 slower than big blade and had a lot of vibration and tiller torque.
Sun Jun 08, 2014 3:55 pm |
