It is currently Sun Jul 06, 2025 9:58 am
Reply to topic  [ 8 posts ]
 Valve lash
Post Valve lash
Ok up graded to 18bl valve springs set my lash
Now it is hard to pull start. Dang thing will hurt you
Has a bad kick back. Is the lash prob wrong?
Sun Jan 06, 2013 10:12 am
Post Re: Valve lash
its possible that u set ur vavles to loose!!!
Sun Jan 06, 2013 11:32 am
Post Re: Valve lash
Factory setting say intake 0.004
And Ext at 0.006
I just reset the at .002 intake and ext at .003
Starts easy now.
Do I take it you can increase torque by play
With your lash? If so which valve lash should I play with.
I also put a alliunium flywheel on the motor
Due to the cast iron one one the motor was Chinese
Do you thank a bunch torque will loss now.
Sun Jan 06, 2013 2:31 pm
Post Re: Valve lash
That may be to tight? Might screw your cam up. Hopefully a more knowledgeable person will clarify
Sun Jan 06, 2013 2:42 pm
Post Re: Valve lash
Too tight will round off a lobe, factory valve settings are around .005-.006
Sun Jan 06, 2013 4:04 pm
Post Re: Valve lash
So set both valves at .005 when I set them before I couldn't
Start the thing.
Sun Jan 06, 2013 4:34 pm
Post Re: Valve lash
What's a lobe?
Sun Jan 06, 2013 4:35 pm
Post Re: Valve lash
The surfaces on your cam that look all crazy that tells the engine what parts to move and how much. I'm sure there is a better explanation. But I'm sure you get the point
Sun Jan 06, 2013 4:43 pm
Users browsing this forum: No registered users and 58 guests
