It is currently Mon Jul 07, 2025 9:26 pm
[ 8 posts ] |
Joel907
 Valve lash
Ok up graded to 18bl valve springs set my lash Now it is hard to pull start. Dang thing will hurt you Has a bad kick back. Is the lash prob wrong?
Sun Jan 06, 2013 10:12 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
 Re: Valve lash
its possible that u set ur vavles to loose!!!
Sun Jan 06, 2013 11:32 am |
Joel907
 Re: Valve lash
Factory setting say intake 0.004 And Ext at 0.006
I just reset the at .002 intake and ext at .003 Starts easy now.
Do I take it you can increase torque by play With your lash? If so which valve lash should I play with.
I also put a alliunium flywheel on the motor Due to the cast iron one one the motor was Chinese Do you thank a bunch torque will loss now.
Sun Jan 06, 2013 2:31 pm |
sela_native
 Re: Valve lash
That may be to tight? Might screw your cam up. Hopefully a more knowledgeable person will clarify
_________________ 1650 ribbed abused by a Gt-35 and push pole reverse
Sun Jan 06, 2013 2:42 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: Valve lash
Too tight will round off a lobe, factory valve settings are around .005-.006
Sun Jan 06, 2013 4:04 pm |
Joel907
 Re: Valve lash
So set both valves at .005 when I set them before I couldn't Start the thing.
Sun Jan 06, 2013 4:34 pm |
Joel907
 Re: Valve lash
What's a lobe?
Sun Jan 06, 2013 4:35 pm |
sela_native
 Re: Valve lash
The surfaces on your cam that look all crazy that tells the engine what parts to move and how much. I'm sure there is a better explanation. But I'm sure you get the point
Sun Jan 06, 2013 4:43 pm |
[ 8 posts ] |
Users browsing this forum: Google [Bot] and 52 guests |
