It is currently Mon Jul 14, 2025 12:38 pm
Reply to topic  [ 60 posts ]  Go to page Previous  1, 2
 What kind of speed you get out of your LT???
Post Re: What kind of speed you get out of your LT???
A hooked boat vs clean boat can make that difference.
Sun Jun 05, 2011 10:43 pm
18 or 19 mph with 25 gdlt on a 1644 gd boat (no hooks) with only me 215 lbs gas and battery. 19 might even be stretching it. 2 people with hunting load i get about 15-16.
Mon Jun 06, 2011 7:23 pm
Now that is a accurate speed.
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Mon Jun 06, 2011 8:57 pm
17*38 Klibert 23GDLT
Mon Jun 06, 2011 8:59 pm
Dont get me wrong, when I move up to a surface drive in a year or two, my longtail will be staying to. For some places they are amazing, but I been running one to long for someone to tell me some bs speed. If 19 in a 6.5 long tail was possible, then why would people need surface drives.
Mon Jun 06, 2011 11:20 pm
I'm running a MB 35 Lt on an F&F 16/52 1/8 hull at around 26-29 depending on the water depth.
Hey ya'll, wachis!
Tue Jun 07, 2011 9:46 am
Tue Jun 07, 2011 10:41 am
Tue Jun 07, 2011 11:01 am
Tue Jun 07, 2011 2:02 pm
I have seen some custom small long tails like modded up to the point of death run in the higher teens but these are almost factor longtails they are talkin about here.
Tue Jun 07, 2011 5:18 pm
my homemade 6hp lt runs in the teens its about 20lbs lighter than a real 6hp godevil and with the governer removed she sounds like shes about to blow anytime but ima run it intill it doesnt run anymore
Tue Jun 07, 2011 6:29 pm
what did u do to remove the governor? did u take out the gear or did ya leave it in?
Thu Jun 09, 2011 10:44 am
My Mudauber longtail Kit#2 has a 13hp Greyhound or harbor frieght engine. I get 18mph in a 1442 G3.
Bought the boat used for $800. Kit cost $800 Engine $259. on sale
www.mudauber.com
Rich
Fri Jun 10, 2011 2:59 pm
Fri Jun 10, 2011 3:05 pm
That is what you get when you cant afford a universal joint, 12 feet of shaft behind a boat.
And not 18mph.
Fri Jun 10, 2011 10:59 pm
Sat Jun 11, 2011 8:54 am
Sat Jun 11, 2011 1:35 pm
I get about 12 to 14 mph in a 16 hp gdlt and a 1644 flat thick hull.
Thu Jun 16, 2011 6:02 pm
Hey ya'll, wachis!
Fri Jun 17, 2011 12:04 pm
Sun Jun 19, 2011 10:47 pm
Users browsing this forum: No registered users and 48 guests
