It is currently Sat Jul 12, 2025 4:20 am
Reply to topic  [ 17 posts ]
 Old gator tail gear ratio
Post Old gator tail gear ratio
I was wondering if I could change the gear ratio on my gator tail I have the marine. Motor and those come with diffrrnt gears than the older models
2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Sun May 19, 2013 11:09 am
Post Re: Old gator tail gear ratio
I thought that the "sweet spot" in stock GTR gearing was 1.2 to 1 on
a 10 pitch GT prop...
If you are going to ask a gear ratio question - you might want to preface
the question with whatever mods you have or intend to add as well as what
prop and pitch you are going to use on final power to the water and a bit of
info on hull and loads...
Good Luck...
Related thread...
viewtopic.php?f=3&t=20486&p=382758&hilit=ratio#p382758
Eat - Sleep - Hunt ! ! !
Sun May 19, 2013 12:32 pm
I got a stage 2. Ima run the regular 10 pitch prop on a 18x48 boat
My boat was quick right when I got it back but now that I put bout 70 hours on it it has slowed down fastest it ever went was 34 with 2 ppl now I'm lucky if I get 30 31 by ma self the only thing I can see is that I changed. Props but this weekend I put my old prop back on and it so wore out its turning 4300 Rpms like nothing and that's where I usually run it at 4300-4400
Sun May 19, 2013 3:10 pm
70 hrs, it's time to check valve lash & probably wouldn't hurt to do a leakdown test. You said normal rpm @ 4300, what are you turning the new prop?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun May 19, 2013 4:05 pm
T-Carl measure that prop an let us know. I got it on step with 7 people and generator plus gear. Was turning 4200 and only was 3/4 throttle. you need a prop capt
Sun May 19, 2013 4:12 pm
Look t-al how you knew it was me
Sun May 19, 2013 4:22 pm
lol im good like that!
Sun May 19, 2013 4:24 pm
Who does that around laffayette area don't wanna bring it to gator tail. Just for a check up ingot a buddy that knows how to do all that but I'm always bugging him
Sun May 19, 2013 4:25 pm
Small prop is 11 1/4 big prop is 11 7/8
Sun May 19, 2013 4:28 pm
12 an 1/4 is what a new one should measure. 1" makes all the difference yea
Sun May 19, 2013 4:30 pm
And i deff need to tinker with my carb is running way to rich brunt over 21 gal in 2 days my plugs are probably filed
Sun May 19, 2013 4:42 pm
I wouldn't consider that getting on step but first night was rolling 5 ppl and generator and all stuff. Rolling 25 I was proud until t-Mac burnt me. Made me feel like I was in a go-devil long tail
And I got that prop off had to lock it and get my brother to step on it
Sun May 19, 2013 4:46 pm
They started putting a 48 tooth bottom gear on the marine engines cuz the 45 tooth would loose out with a load. But it was fast as hell empty with the 45 tooth. Alex has a 45 tooth bottom gear and so does Tmac.
Mon May 20, 2013 1:37 pm
Man that sounds like a really nice skiff in Your Signature that thing must run
Mon May 20, 2013 7:43 pm
Mon May 20, 2013 8:02 pm
But man that's a nice skiff
Mon May 20, 2013 8:15 pm
Mon May 20, 2013 8:41 pm
Users browsing this forum: No registered users and 119 guests
