It is currently Tue Jul 15, 2025 11:33 am
[ 6 posts ] |
Stripped Zerk Fitting on PD
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
My grease fitting that is behind the metal plug came out. It seems like the threads in the LU housing are stripped. I'm trying a JB Weld option now but I don't have much confidence in it. How would I go about fixing this and does anyone know what the original size of the fitting is?
Mon Aug 05, 2013 11:40 pm |
ha2
 Re: Stripped Zerk Fitting on PD
Original thread size is 1/4 28 for the zerk
_________________ 1856 Phowler commercial hull with extra flotation so I can run shallower. Pushed by a stock Prodrive until my wife gives me more money
Tue Aug 06, 2013 4:01 am |
banded-mallard
easy fix, drill out the hole bigger and rethread. They make all kinds of sizes of zerts. You can get all of this at any local hardware store. Get the bigger zert with larger size first, then get the tap to match threads and then get the drill bit to match the tap. Very easy. I wouldn't JB weld that bitch, take chance of falling off due to high vibration.
Tue Aug 06, 2013 5:23 am |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
When drilling and tapping dip the end of the drill bit in some grease and also the end of your Tap, helps keep metal shavings from dropping down into your housing.
Tue Aug 06, 2013 5:31 am |
banded-mallard
Tue Aug 06, 2013 5:32 am |
Ducksmuggler
Joined: Mon Jun 15, 2009 4:47 pm Posts: 146 Location: Buffalo county Wis.
Also use the right size drill bit
_________________ 18x48 brothers with a 36 PD passing or pulling everything in these parts
Wed Aug 07, 2013 8:02 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 41 guests |
