It is currently Mon Jul 14, 2025 10:12 pm
Reply to topic  [ 18 posts ]
 any of yall recognize this boat
Post any of yall recognize this boat
Hey yall, im Michael from Baton Rouge. Ive been reading on this sight in research for buying a new boat. Decided on an outboard rig but love the sight because of all the local guys and fellow duck hunters. Yall definetly have the most info on custom built boats. With that said, I just bought this boat second hand and the previous owners weren't sure who built it. I know its not a mud rig but the last owner said the guy before him had a mud motor on it so I figured yall might recognize it. Hull is registered as a 1984. Little over 17', 60'' bottom. Last owner added the console, back deck, and motor. Heres some pics
19x48 rickey aucoin bateau
37efi gtr
Wed Apr 02, 2014 2:32 pm
Post Re: any of yall recognize this boat
There are so many boats built like these in garages all across south la. You'll probably never find out who built it.
Wed Apr 02, 2014 3:34 pm
Yeah i know. Figured it was a long shot. What yall think about it regardless? She runs almost 50, but you cant run that fast realistically cuz it starts bouncing real bad. Already bent the tabs down a little, idk what else to do to help it
37efi gtr
Thu Apr 03, 2014 9:14 am
I'd guess instagator given the transom steps.
Thu Apr 03, 2014 9:19 am
Thu Apr 03, 2014 9:57 am
those are pods dip shit.......
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Thu Apr 03, 2014 10:06 am
The pods were definetly added after the boat was built. The welds on them are shit. Luckily theyre sealed off. What yall think about the porpoising? I can barely trim up an it starts hopping. cant hardly run over 45-5000rpms. Transom angle is good. So im thinking just too much weight in the back. Will a fin on the motor help? Maybe add some front weight? Has 2 batterys and toolbox in front already. Could the pods cause it? Theyre an inch off the bottom so i cant imagine
37efi gtr
Thu Apr 03, 2014 10:31 am
I put a stingray hydrofoil on my little outboard and it stopped all porpoising completely. Use to be I couldn't run the boat empty with just me in the back driving and it would bounce. Added the hydrofoil and I can put as much weight as I want back there and she wont bounce. Only thing it affected other than that was my turning. Can't turn in as tight of circles at high speeds or she will start to grab air. I think a good hydrofoil would be the fix to your problem
Thu Apr 03, 2014 10:48 am
Looks like an Uncle J. :lol:
Thu Apr 03, 2014 10:52 am
My buddy has an old Charles Leonard that looks just like that one. The deck lid is even the same
Thu Apr 03, 2014 11:04 am
Thu Apr 03, 2014 12:42 pm
what ever happened to Uncle J?
Thu Apr 03, 2014 1:06 pm
Move that jackplate up where it belongs.
Thu Apr 03, 2014 1:43 pm
Might have been a jump boat, bottom is a lil beat up. Nothing serious tho. Maybe 1/8 deep hook in a spot or two. And i think the jackplate is in the right spot. All the way down, the cav plate is even with boat bottom. Someone added to the transom an made it tall as shit. Top bolt on the jackplate is 20in
37efi gtr
Fri Apr 04, 2014 6:14 pm
Hydrofoil may help or a small set of tabs. The fin would be cheaper if it would work.
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Fri Apr 04, 2014 10:06 pm
Sounds like you need a different prop also
16x42 Charles Leonard ... Sold
18x46 Gator Tail w/ 35 gtr stage 1 by hoyt
Fri Apr 04, 2014 11:06 pm
Should be turning 6000 with that motor you have some options on prop that may help with your issue also
Fri Apr 04, 2014 11:07 pm
The motor will turn 6000 easy but i mean i cant runn it that high cuz its uncontrolable. Has a solas 13x19. I do need to talk with the prop guy. Might try a 4 blade. And im gonna snag up a doelfin this weekend
37efi gtr
Sat Apr 05, 2014 8:05 am
Users browsing this forum: Google [Bot] and 112 guests
