It is currently Wed Jul 16, 2025 2:02 am
Reply to topic  [ 30 posts ]
 not what i was hoping for.
Post not what i was hoping for.
Me and the wife went out today in the bayou to run the boat before tmrws ride and i was not impressed at all. Went from holding 30 by myself to 26. And 24 with me and the wife. I dont like it at all. Any suggestions? I had an empty 35 quart k2 as a seat and a crankin battery in the back, 6 gallons of fuel, small tool box, trollin motor, and life jackets.
35 GTR chasin a BBC 1848
Sat May 03, 2014 8:03 pm
Post Re: not what i was hoping for.
40HP Gatortail
Sat May 03, 2014 8:09 pm
What's changed with the motor?
WC 1848 Bateau w/ 36 PD FPR
No wasnt boggin down. Held 3660, seemed to be what was working for it. Its in the stock hole. Whichever that one is. Motors brand new, has 45 minutes on it. And slingin a 2 blade.
Sat May 03, 2014 8:13 pm
40HP Gatortail
Sat May 03, 2014 8:15 pm
Lol yeh. Im runnin a gutted muffler, but i dont see that veing the problem??
Sat May 03, 2014 8:17 pm
Move the wife to the middle. Of the boat and see if that helps my boat runs better with less weight in front
- Mark Twain
Sat May 03, 2014 8:19 pm
Sat May 03, 2014 8:21 pm
Sorry, but I obviously know less about your rig than everyone else. What brand/HP is the motor?
Sat May 03, 2014 8:22 pm
POS GTR
- Mark Twain
Rpms are too low. Check WOT in neutral and make sure you are getting 4350 or 4750 depending on your coils.
Sat May 03, 2014 8:23 pm
Well Kaleb that's about what mine ran today with 2 people and a I've chest. Anywhere from 26-28. But I think my boat is a little heavier too. Don't see you adding a couple of pounds to it and it dropping 4 mph!
Sent from my beeper
Sat May 03, 2014 8:28 pm
Your throttle cable could have slipped in the clamp as well, and you aren't getting full throttle. Check those 2 easy things first. You should be turning 4000 rpm at least.
Sat May 03, 2014 8:29 pm
So on trailer 4300-4700? In gear r neutral?
Ummm.....either or, as long as there isn't a load on the prop.
Sat May 03, 2014 8:30 pm
Sun May 04, 2014 8:31 am
have also seen the valves leaking bad right out the crate
I gave up mud motors
Sun May 04, 2014 8:58 am
Mine did the same thing. Adjust the governor and you'll be good to go. Also while the screw driver is in your hand adjust idle if you need to.
The journey has begun. Custom design not road tested. Did you build it to specs of known proven hull or is this your own hull design? If not engine issue you may be experiencing new hull design syndrome. Hope it's only engine issue.
Sun May 04, 2014 9:17 am
Sun May 04, 2014 9:22 am
Na, we got her fixed up now. Turnin 4150 in the water at 28mph with a 65 and 35 icechest full.
Mon May 05, 2014 8:34 am
What was the problem?
Mon May 05, 2014 9:18 am
Wasnt gettin full throttle and had to play with govenor a lil bit
Mon May 05, 2014 10:01 am
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon May 05, 2014 10:06 am
Glad you got it fixed!
Mon May 05, 2014 10:29 am
True dat! Thanks gor the help fellas. And dean, get fucked. Theres nothing wrong with the design. Might not be the best but its my first one.
Mon May 05, 2014 5:58 pm
1646 Gatortail dragging a stage 1 GTR
Mon May 05, 2014 7:55 pm
Mon May 05, 2014 8:04 pm
Tue May 06, 2014 10:55 am
Users browsing this forum: Google [Bot] and 97 guests
