It is currently Fri Jul 18, 2025 1:37 am
Reply to topic  [ 21 posts ]
 Battery Up Front
Post Battery Up Front
For those of you running a battery under the front deck, are you using a remote terminal post in the back or are you running straight to the motor?
I'm looking for a terminal I can use that looks safe and makes sense and can't find one. Let me know if any of you have something that works. Thanks!
Sun May 04, 2014 9:10 pm
Post Re: Battery Up Front
Like this?
http://www.genuinedealz.com/blue-sea-sy ... inch-studs
I have a battery up front in my little fishing boat. Works fine, use #2 wire to the back.
Mon May 05, 2014 4:27 am
^^ That's what i have in mine. Works fine. Got it for a local boat shop Like 15 bucks.
Mon May 05, 2014 5:43 am
Also could use a single post just like the one pictured for the ground and a battery switch for the positive.
Mon May 05, 2014 7:14 am
whats your reasoning?
You will have to run a larger wire to not overheat.
I gave up mud motors
Mon May 05, 2014 7:25 am
I just want the majority of weight up front. Big cable is not a problem. I'm actually most concerned with the battery being located near the tank, but will make sure there's nothing dangerous
Mon May 05, 2014 10:50 am
MMT Moderator
GTB 1860 w/ 2019 GTR40XD-HO
Mon May 05, 2014 11:17 am
^this. And make sure your battery connections are tightened with a wrench. Loose connection can sometimes spark.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Mon May 05, 2014 3:54 pm
Do you know if I would have to run a separate cable for the ground wire all the way back as well? Or could I locally ground that remote terminal?
Electricity can be perplexing sometimes.
Mon May 05, 2014 4:14 pm
Run your hot and ground all the way to the back.
Mon May 05, 2014 4:47 pm
Thank you! 3 bucks a foot on an 18 foot boat won't be cheap but will be worth it for getting on plane (I have a longtail)
Mon May 05, 2014 6:47 pm
If you have time, they have decent pricing on marine wire and what not.
1754 GTB / 35 GTR
Mon May 05, 2014 8:20 pm
2 gauge should be plenty, right?
Mon May 05, 2014 9:04 pm
This might be cheaper. Haven't checked shipping though:
http://gregsmarinewiresupply.com/Zen/in ... 42c4b9c7e9
Mon May 05, 2014 10:26 pm
Get some thick ass 20 foot jumper cables shouldn't be more than 50 bucks
Tue May 06, 2014 5:23 am
2 Ga will be more than enough. This is what I did with mine. You can find these on amazon and make hooking and unhooking accessories a breeze. Put a pair up front to hook your batteries, long cables, and accessories into it, and another pair astern to hook any other accessories (charger) and motor up.
http://www.amazon.com/Blue-Sea-Systems- ... ystems+150
Tue May 06, 2014 5:30 am
www. pacerwiregroup.net has it for $2.78 a foot.
Tue May 06, 2014 10:13 am
Just saw 20 foot 2 gauge jumper cables at autozone for $50
Thu May 08, 2014 8:35 am
That's about $1.25 a foot
Thu May 08, 2014 8:36 am
Thu May 08, 2014 10:12 am
Try a car stereo shop for a distribution block.
Semper Fi
16x38 WC Skiff 35 MB HD
Sun May 11, 2014 7:49 pm
Users browsing this forum: No registered users and 72 guests
