Duckaholic-Anonymous
 Battery Up Front
For those of you running a battery under the front deck, are you using a remote terminal post in the back or are you running straight to the motor?
I'm looking for a terminal I can use that looks safe and makes sense and can't find one. Let me know if any of you have something that works. Thanks!
Sun May 04, 2014 9:10 pm |
Ducknut
Joined: Wed Apr 15, 2009 5:38 pm Posts: 238 Location: MN
 Re: Battery Up Front
Like this? http://www.genuinedealz.com/blue-sea-sy ... inch-studsI have a battery up front in my little fishing boat. Works fine, use #2 wire to the back.
Mon May 05, 2014 4:27 am |
mud slinger 69
Joined: Sun Aug 28, 2011 4:27 pm Posts: 1194 Location: Utah
^^ That's what i have in mine. Works fine. Got it for a local boat shop Like 15 bucks.
_________________ We ant just mormons and polyganists we got rednecks too
Mon May 05, 2014 5:43 am |
gfowel
Joined: Thu Mar 01, 2012 4:52 pm Posts: 1024 Location: Florida
Also could use a single post just like the one pictured for the ground and a battery switch for the positive.
Mon May 05, 2014 7:14 am |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
whats your reasoning?
You will have to run a larger wire to not overheat.
_________________ I gave up mud motors
Mon May 05, 2014 7:25 am |
I just want the majority of weight up front. Big cable is not a problem. I'm actually most concerned with the battery being located near the tank, but will make sure there's nothing dangerous
Mon May 05, 2014 10:50 am |
WestEndAngler
MMT Moderator
Mon May 05, 2014 11:17 am |
kibb
^this. And make sure your battery connections are tightened with a wrench. Loose connection can sometimes spark.
Mon May 05, 2014 3:54 pm |
Do you know if I would have to run a separate cable for the ground wire all the way back as well? Or could I locally ground that remote terminal?
Electricity can be perplexing sometimes.
Mon May 05, 2014 4:14 pm |
kibb
Run your hot and ground all the way to the back.
Mon May 05, 2014 4:47 pm |
Thank you! 3 bucks a foot on an 18 foot boat won't be cheap but will be worth it for getting on plane (I have a longtail)
Mon May 05, 2014 6:47 pm |
krogers
Joined: Fri Oct 29, 2010 8:24 am Posts: 1958 Location: Bristol, FL
http://www.genuinedealz.com/If you have time, they have decent pricing on marine wire and what not. Sent from my iPhone using Tapatalk
_________________ 1754 GTB / 35 GTR
Mon May 05, 2014 8:20 pm |
2 gauge should be plenty, right?
Mon May 05, 2014 9:04 pm |
This might be cheaper. Haven't checked shipping though: http://gregsmarinewiresupply.com/Zen/in ... 42c4b9c7e9Sent from my iPhone using Tapatalk
Mon May 05, 2014 10:26 pm |
mud slinger 69
Get some thick ass 20 foot jumper cables shouldn't be more than 50 bucks
Tue May 06, 2014 5:23 am |
schauv01
Joined: Wed Oct 03, 2012 6:50 am Posts: 565 Location: Union, LA
2 Ga will be more than enough. This is what I did with mine. You can find these on amazon and make hooking and unhooking accessories a breeze. Put a pair up front to hook your batteries, long cables, and accessories into it, and another pair astern to hook any other accessories (charger) and motor up. http://www.amazon.com/Blue-Sea-Systems- ... ystems+150Sent from my iPad using Tapatalk HD
Tue May 06, 2014 5:30 am |
gfowel
www. pacerwiregroup.net has it for $2.78 a foot.
Tue May 06, 2014 10:13 am |
Just saw 20 foot 2 gauge jumper cables at autozone for $50
Thu May 08, 2014 8:35 am |
That's about $1.25 a foot
Thu May 08, 2014 8:36 am |
gfowel
Thu May 08, 2014 10:12 am |
tylerduckman
Joined: Mon Jan 30, 2012 1:40 pm Posts: 844 Location: Tyler TX
Try a car stereo shop for a distribution block.
_________________ Semper Fi
16x38 WC Skiff 35 MB HD
Sun May 11, 2014 7:49 pm |
