It is currently Tue Jul 15, 2025 10:43 pm
Reply to topic  [ 16 posts ]
 Will this destroy aluminum?
Post Will this destroy aluminum?
I have some old ass steelflex on my hull and any slickness properties are now more like an ultra fine sandpaper. I want to get rid of it but there's no way I can sit through scraping at it with a heat gun.
Will the quick strip pad and an angle grinder do the trick? I don't want to grind the aluminum away but the material on the disc is quite flexible and on the surface looks like it won't damage metal. The package says it's meant for epoxy. I just want the "experts" opinions.
Sun May 11, 2014 3:52 pm
Post Re: Will this destroy aluminum?
I can tell u how to find out but then I would have to kill you.. lol
Sent from my HTC One mini using Tapatalk
Sun May 11, 2014 4:11 pm
no but it'll leave swirl/grind marks
Sun May 11, 2014 4:41 pm
Why do you want to take the steel flex off? Is it chipping off? If so that disc should do it, but there only one way to find out. Typically I would use the same 36 grit wheel I used to prep the hull to put steel flex on to take it off. Get a good mask and eye protection or a big bottle of Jim beam.
http://www.gatorglide.com/
gatorheads@comcast.net
Sun May 11, 2014 6:25 pm
It's chipping all under, there are hooks that probably started the chipping. I just tried this thing and it's great, stuff flies off. Wish I found it for my other boats I've had
Sun May 11, 2014 6:48 pm
That's good to know. I've got to get the SF off my airboat. Been dreading it myself. I use the heat gun and scraper last time, it a lot cleaner but a pain in the ass. This will be my last one though.
Sun May 11, 2014 7:02 pm
Will a chemical stripper not work??? It damn sure won't scar the aluminum .
Semper Fi
16x38 WC Skiff 35 MB HD
Sun May 11, 2014 7:47 pm
Possibly, but it would be a lot more expensive and the swirl marks will disappear with paint
Sun May 11, 2014 7:54 pm
That pad will take aluminum off pretty quick so don't stay in one spot long I used it before on aluminum on a drill and it was still taken alum off at slow rpms
Sun May 11, 2014 9:53 pm
Its too porous. It will clog it up and be useless very quick. If your going to do something like that, use a SS wire wheel. It will do less damage and be more forgiving to the aluminum , remove the steel flex, and won't clog.
Mon May 12, 2014 4:56 am
Mon May 12, 2014 6:51 am
Mon May 12, 2014 8:06 am
This pad did not destroy aluminum. Worked very well but was very dusty and these things wear out FAST. And they're $10 each. Bought some heavy duty stripper from Home Depot to remove some cheap bed liner I put on the floors and deck and tried it on a patch of old flex steel I left on the bottom - turned the stuff into butter and I wish I had started with the stripper, would have been much cheaper
Mon Jun 09, 2014 7:05 pm
Mon Jun 09, 2014 7:06 pm
Mon Jun 09, 2014 7:07 pm
Stainless wire wheel is the worst thing to use on aluminum. The stainless bits that stay on the aluminum sets up galvanic corrosion that will cause issues down the road. I know many people use them, but they shouldn't.
18'x54"CC Hanko/ 36PD
Tue Jun 10, 2014 2:03 am
Users browsing this forum: No registered users and 123 guests
